Does anybody have a digital clock widget I could have? The canned one with HabPanel doesn’t allow you to have change the background.
Best, Jay
Best, Jay
which clock are you referring to? You can override any style in HabPanel if you supply your own css file
On a HabPanel config screen; add widget then clock. I have the digital one set.
I think it’s this one from the source code → app/widgets/clock/clock.widget.js
Best, Jay
Unfortunately, you cannot remove the background on that one. That’s one of my pet peeves in HabPanel widgets, the box itself is styled and outside the scope of the widgets themselves. I suggest you just use a regular template widget and put the widget-clock in it. HTML would be like this (make sure you check no background and dont wrap:
<style>
.customClock {
background-color: #232323;
color: red;
width: 100%;
height: 100%
</style>
<div class='customClock'>
<widget-clock ng-model='{ mode: "Digital", analog_theme: "dark", format: "h:mm a" }'></widget-clock>
</div>
Good morning Lucky!
Thanks for helping me again; the only issue is I’m looking for the same color for the back as the default background has for HabPanel (that dark blue); do you know the color code for that? I turned ON no background think it would be transparent but it’s just grey.
Also, is there a way to turn it to a 12 hour clock vs. 24 hour clock?
Best, Jay
Based off your screenshot (through a color droplet) #082e49
You can pick any format you like:
hh:mm:ss a
<style>
.customClock {
color: red;
width: 100%;
height: 100%
</style>
<div class='customClock' ng-init='m={mode: "Digital", analog_theme: "light", digital_format: "hh:mm:ss a" }'>
<widget-clock ng-model='m'></widget-clock>
</div>
Code is here:
Thank you! I took your latest code again and it worked!
Best, Jay
