Cloning a running openhab system (SSD to SSD)
  • Platform information:
    • Hardware: Raspberry 4 - 4 GB Ram
    • openHab Version: Openhab 3.4
I have two SSD´s connected to my Raspberry. Each of them have 256 GB.
Today i had a Powerbreak and the openhab installation crashed. The file and disk structure of the first SSD was destroyed. So i used my second SSD (cloned drive). This was not a problem and the system runs fine. At this problem a question came up.
I have used DD for cloning a running system. As far i know it is not the recommended method to clone a running system. It can work … but it can also create problems.
How is it possible to clone a running openhab (whole system) from SSD 1 (/dev/sda/ ) to SSD 2 ( /dev/sdb/ ) ???
So that in case of drive or data problems i can boot with the other one
Greetings
I use dattobd to create image snapshots of my running machine for backup purposes (I’m using urbackup):
Check out the documentation there, you can use it to create a snapshot of your system and dd this snapshot data to your second ssd.
Note however that kernels 5.10 and up are not yet supported.
