Hi all,
I’ve decided to share my experience with offline voice control and openHAB, as it’s working surprisingly well and I haven’t seen it around here (yet). All of this is still in heavy development, so if you have any kind of improvement ideas, pls. feel free to share them with me.
What’s involved:
I’m running some Raspberry Pis as satellites around the house to capture the voice commands. (lately it’s some Raspberry Pi Zero 2 Ws with Seeed ReSpeaker Mic Hats)
Those satellites use the picovoice hotword detection (“Porcupine”) as well as picovoice’s speech to intend engine “Rhino”.
The software on the satellites provides the intensions via MQTT to openHab.
Within openHAB I’m using a rule to interpret the received commands to actions as well as VoiceRSS to output feedback via my Sonos Speakers.
Setting up the satellites:
Start with a fresh Raspbian installation and follow the instructions for the ReSpeaker. (e.g. 4 Mic Array or the 2 Mic Hat). Actually this should work with any kind of microphone, but I’ve had the ReSpeakers around.
Once the ReSpeakers (and their nice LEDs) are working we can install Porcupine and Rhino. I guess it also works with the picovoice SDK, but I started with both enginges separately and don’t really see a reason why to migrate.
Now we have to create our model and/or wake work via the picovoice console.
I’m using the built in wake words (why should I call this thing anything but Jarvis
) and a german Rhino context model: Jarvis.txt (3.2 KB) This file should actually be called *.yml, but the board does not allow *.yml files.
If I recall correctly, we should have nearly everything available on the satellites except the MQTT functionality, so we install the Paho MQTT with
pip3 install paho-mqtt
Now we’re ready to run everything on our satellite and post it on our MQTT server. So lets create the everything we need.
Create a folder for jarvis. (I’m doing this directly in the home folder)
cd ~
mkdir jarvis
From the seeed examples we’ll use the code that deals with the LEDs on the Respeakers and copy them into our folder.
Depending on the type of ReSpeaker (we should know this from the Respeaker Setup) used this can be
cp 4mics_hat/interfaces/* jarvis/
or
cp mic_hat/interfaces/* jarvis/
Now let’s move into the folder:
cd jarvis
In case we want to use a context model that’s not english we have to download the corresponding Rhino library.
For German that would be:
wget https://github.com/Picovoice/rhino/blob/master/lib/common/rhino_params_de.pv?raw=true
Last but no least we need to get the Rhino Context model file (*.rhn, not the *.yml I’ve posted here), which was created earlier via the picovoice console and can be downloaded from there, into the folder. (I’ve used SCP to copy it there)
Now we can create the actual code that provides the command to MQTT:
nano jarvis.py
#!/usr/bin/env python3
import struct
import pyaudio
import pvporcupine
import pvrhino
import time
import pixels as p
import paho.mqtt.client as mqtt
import yaml
import random
import json
p.pixels.wakeup()
mqtt_broker_url = "xxx.xxx.xxx" #Set this to your MQTT Broker URL that's known to openHAB
mqtt_broker_port = 1883
mqtt_base_topic ="jarvis"
access_key = "xxx123xxx123xxx123" #Picovoice API Code
rhino_context = "xxxxxx.rhn" # Filename of Rhino's Context Model
rhino_model = "rhino_params_de.pv" #In case you use a german rhino model. Can be changed to other languages
listen_seconds = 7 #How long does Jarvis listen after the wakeword was detected
porcupine = None
rhino = None
pa = None
audio_stream = None
mqtt_client = None
def say(text): #You'll realize that this is not used at the moment, but I've used it for debugging and might use it going forward as well.
mqtt_client.connect(mqtt_broker_url, mqtt_broker_port)
mqtt_client.publish(topic=mqtt_base_topic + "/say", payload=text, qos=0, retain=False)
mqtt_client.disconnect()
def sendCommand(json):
mqtt_client.publish(topic=mqtt_base_topic + "/command", payload=json, qos=0, retain=False)
try:
porcupine = pvporcupine.create(access_key=access_key, keywords=["jarvis"])
rhino = pvrhino.create(access_key=access_key, context_path=rhino_context, model_path=rhino_model)
pa = pyaudio.PyAudio()
audio_stream = pa.open(
rate=porcupine.sample_rate,
channels=1,
format=pyaudio.paInt16,
input=True,
frames_per_buffer=porcupine.frame_length)
mqtt_client = mqtt.Client()
time.sleep(0.7)
p.pixels.off()
while True:
pcm = audio_stream.read(porcupine.frame_length, exception_on_overflow = False)
pcm = struct.unpack_from("h" * porcupine.frame_length, pcm)
keyword_index = porcupine.process(pcm)
if keyword_index >= 0:
print("Hotword Detected")
p.pixels.wakeup()
is_finalized = False
timeout = time.time() + listen_seconds
while True:
pcm = audio_stream.read(rhino.frame_length, exception_on_overflow = False)
pcm = struct.unpack_from("h" * rhino.frame_length, pcm)
is_finalized = rhino.process(pcm)
if is_finalized:
inference = rhino.get_inference()
if inference.is_understood:
p.pixels.think()
sendCommand(json.dumps(inference))
break;
if (time.time() > timeout):
break;
p.pixels.speak()
time.sleep(2)
p.pixels.off()
finally:
if porcupine is not None:
porcupine.delete()
if rhino is not None:
rhino.delete()
if audio_stream is not None:
audio_stream.close()
if pa is not None:
pa.terminate()
OK, now we get a nicely usable JSON file posted to our MQTT Server in case the command was known and understood.
I’m running the jarvis.py as a system service on the satellites.
Setting up openHAB:
I assume we have a working openHAB instance including a functioning MQTT setup.
First we have to create Jarvis thing in openHab which has 2 channels.
UID: mqtt:topic:localMQTTBroker:jarvis
label: Jarvis MQTT
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:localMQTTBroker
channels:
- id: say
channelTypeUID: mqtt:string
label: say
description: ""
configuration:
stateTopic: jarvis/say
- id: command
label: command
description: null
configuration:
stateTopic: jarvis/command
I’m still using textual item creation, so I’ve created two items for the two channels:
String jarvis_Say "Jarvis sagt: [%s]" (others) {channel="mqtt:topic:localMQTTBroker:jarvis:say"}
String jarvis_Command "Kommando: [%s]" (others) {channel="mqtt:topic:localMQTTBroker:jarvis:command"}
Now we should get the input from our satellites to openHAB and we can start interpreting them via a rule. The intentions or commands provided via the satellites are partially translated via map files. Create your own based on your Rhino context model and what you’re trying to achieve.
I’m using the following:
jarvisColor.map:
blau=240
grün=120
orange=30
pink=300
lila=270
rot=0
gelb=45
weiß=T100
weiss=T100
warm=T100
kalt=T0
jarvisIntensity.map:
Null\ Prozent=0
Zehn\ Prozent=10
Zwanzig\ Prozent=20
Dreissig\ Prozent=30
Vierzig\ Prozent=40
Fünfzig\ Prozent=50
Sechzig\ Prozent=60
Siebzig\ Prozent=70
Achtzig\ Prozent=80
Neunzig\ Prozent=90
Hundert\ Prozent=100
jarvisLocation.map:
Badezimmer=Badezimmer
Bad=Badezimmer
Schlafzimmer=Schlafzimmer
Flur=Flur
Küche=Küche
Wohnzimmer=Wohnzimmer
Ess\ bereich=Essbereich
Büro=Büro
Eingangsbereich=Flur
=not\ defined
jarvisScene.map:
Ambiente=abend
Abendstimmung=abend
Abendessen=abendessen
Fernsehen=tv
Gammel\ Stimmung=tv
Fernseh\ Stimmung=tv
Fauler\ Sonntag=tv
jarvisState.map:
an=1
aus=0
ein=1
auf=1
ab=0
Here’s my rule at the moment. (I’m sure this is far from ideal and I could potentially also use openHAB’s context model to make things more efficient)
rule "Say Rule"
Item jarvis_Say received update
say(jarvis_Say.state.toString, "voicerss:deAT", "sonos:PLAY5:RINCON_XXXXXXXXXXXXXXXX", new PercentType(50))
rule "Command Rule"
Item jarvis_Command received update
val cmd = jarvis_Command.state.toString
var intend = transform("JSONPATH", "$[1]", cmd)
var location = transform("MAP", "jarvisLocation.map", transform("JSONPATH", "$[2].location", cmd))
if(location == cmd) location = "not defined"
var success = false
switch(intend) {
case "changeState":
var state = transform("JSONPATH", "$[2].state", cmd)
var onOff = if( transform("MAP", "jarvisState.map", state) == "1") ON else OFF
switch(location) {
case "Badezimmer": {
EG_Bad_L.sendCommand(onOff)
success = true
case "Schlafzimmer": {
//OG_Schlafz_L.sendCommand(onOff)
success = true
case "Flur": {
EG_Eing_L.sendCommand(onOff)
success = true
case "Wohnzimmer": {
EG_Wohn_L.sendCommand(onOff)
success = true
case "Essbereich": {
EG_Ess_L.sendCommand(onOff)
success = true
case "Büro": {
EG_Buero_L.sendCommand(onOff)
success = true
case "Küche": {
EG_Kueche_L.sendCommand(onOff)
success = true
case "not defined": {
if(onOff == ON) {
EG_Ess_I.sendCommand(onOff)
grgbwLamp_WohnzTV.sendCommand(onOff)
else egAllLightsKNX.sendCommand(OFF)
success = true
case "changeColor":
var colorCommand = transform("JSONPATH", "$[2].color", cmd)
colorCommand = transform("MAP", "jarvisColor.map", colorCommand)
if(colorCommand.startsWith("T"))
var temp = Integer::parseInt(colorCommand.substring(1))
switch(location) {
if(rgbwLamp_WohnzTV.state == ON) rgbwLamps_EssbInd_Temp.sendCommand(temp)
if(rgbwLamps_Living.state == ON) rgbwLamps_Living_Temp.sendCommand(temp)
success = true
if(rgbwLamps_EssbInd.state == ON) rgbwLamps_EssbInd_Temp.sendCommand(temp)
success = true
case "Küche": {
if(ikZb_Kueche.state == ON) ikZb_Kueche_Temp.sendCommand(temp)
success = true
if(rgbwLamp_WohnzTV.state == ON) rgbwLamp_WohnzTV_Temp.sendCommand(temp)
success = true
else
var hue = Integer::parseInt(colorCommand)
switch(location) {
if(rgbwLamp_WohnzTV.state == ON) rgbwLamp_WohnzTV_Color.sendCommand(hue+",100,100")
if(rgbwLamps_Living.state == ON) rgbwLamps_Living_Color.sendCommand(hue+",100,100")
success = true
if(rgbwLamps_EssbInd.state == ON) rgbwLamps_EssbInd_Color.sendCommand(hue+",100,100")
success = true
success = true
success = true
case "setLightIntesity":
var intensity = Integer::parseInt(transform("MAP", "jarvisIntensity.map", transform("JSONPATH", "$[2].intensity", cmd)))
//logInfo("Jarvis Light intensity", "Setting light level to " + intensity + " in location " + location)
switch(location) {
case "Flur": {
ikZb_Eingang_Dim.sendCommand(intensity)
success = true
rgbwLamps_Living_Dim.sendCommand(intensity)
rgbwLamp_WohnzTV_Dim.sendCommand(intensity)
success = true
ikZb_Essbereich_Dim.sendCommand(intensity)
success = true
case "Küche": {
ikZb_Kueche_Dim.sendCommand(intensity)
success = true
if(rgbwLamp_WohnzTV.state == ON) rgbwLamp_WohnzTV_Dim.sendCommand(intensity)
if(rgbwLamps_Living.state == ON) rgbwLamps_Living_Dim.sendCommand(intensity)
if(rgbwLamps_EssbInd.state == ON) rgbwLamps_EssbInd_Dim.sendCommand(intensity)
if(ikZb_Eingang.state == ON) ikZb_Eingang_Dim.sendCommand(intensity)
if(ikZb_Kueche.state == ON) ikZb_Kueche_Dim.sendCommand(intensity)
success = true
case "setRaffstores":
jarvis_Say.postUpdate("Ich weiß, dass ich das können sollte, aber so weit bin ich leider noch nicht.")
success = true
case "setScene":
var scene = transform("JSONPATH", "$[2].scene", cmd)
var targetScene = transform("MAP", "jarvisScene.map", scene)
scn_House.postUpdate(targetScene)
success = true
case "setRaffstoreLamellen":
success = true
case "setCleaning":
if(location == "not defined") roboRockcontrol.sendCommand("START")
else
val segmentCommand = "{\"segment_ids\": [\"" + transform("MAP", "rockoSegments.map", location) + "\"],\"iterations\": 1,\"customOrder\": true}"
roboRockSegment.sendCommand(segmentCommand)
jarvis_Say.postUpdate("OK, wir kümmern uns drum.")
success = true
case "stopCleaning":
roboRockcontrol.sendCommand("HOME")
//jarvis_Say.postUpdate("OK, wir kümmern uns darum.")
success = true
if(!success) jarvis_Say.postUpdate("Ich fürchte das geht nicht.")
I hope this essay is useful for someone. As said: I’m at the very beginning of this whole thing and there’s much room for improvement, but I’m sure there are some smart people in the community that can actually give me some hints. ![]()
Best, C
