Not sure this is the right place to post this, however my cloud connection keeps failing and reconnecting, every few seconds.
This is my configuration:
Ip = 192.168.1.61
Release = Raspbian GNU/Linux 11 (bullseye)
Kernel = Linux 5.10.92-v7+
Platform = none
Uptime = 0 day(s). 0:4:12
CPU Usage = 49.37% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 2.92, 5m: 1.89, 15m: 0.81
Memory = Free: 0.05GB (6%), Used: 0.89GB (94%), Total: 0.94GB
Swap = Free: 2.33GB (100%), Used: 0.00GB (0%), Total: 2.33GB
Root = Free: 51.41GB (91%), Used: 4.47GB (9%), Total: 58.29GB
Updates = 14 apt updates available.
Sessions = 2 session(s)
Processes = 141 running processes of 32768 maximum processes
And this is just a sample of the log:
16:26:09.109 [INFO ] [.io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 5f49579f-2856-4e6e-9321-637b68f12fb5, base URL = http://localhost:8080)
16:26:41.313 [INFO ] [.io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 5f49579f-2856-4e6e-9321-637b68f12fb5, base URL = http://localhost:8080)
It’s disconnected and reconnected three times while I have writing this post.
Any reason why this should be happening?
It’s worth mentioning that I recently upgraded to openhab3 and my hue bridge on the hue binding does the exact same thing. I have removed the hue binding to see if that was the cause, it makes no difference. I will put the hue issue in another post.
Thanks.
Mike.
