I know there are quite a few posts about the cloud setup and issue, many of which I read before posting…My cloud connector showed in the logs that it installed properly, I matched the uuid and secret, and there are no issues showing in the logs…but, it won’t go online. All I need it for is remote access, no third party at this time. If it matters…The last time it was connected was over 2 years ago.
Have you uninstalled the cloud binding, stopped OH, manually removed the current UUID from the file, cleaned the cache, reinstalled the binding and used the new UUID?
Also as @opus mentioned have you checked your Java version?
If you can’t get your account online, please verify this suggestion from the documentation:
For best compatibility, namely with the openHAB Cloud service myopenhab.org and the Eclipse IoT Marketplace, the minimum recommended Java 8 revision is “161”. Attention: Most package managers serve an older revision . Check your current Java version by opening a command line console and typing java -version :
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) Client VM (build 25.121-b13, mixed mode)
