Hello everybody,
I’m a new user here on the forum and I’m trying to adapt my X10 old installation with the aid of the cm11a binding.
I can trigger switches and dimmers and I’d like to intercept the X10 commands given by the in-wall modules in the apartment to trigger events for items different than X10 ones (in my case I need to turn off both an RF-controlled led ribbon and a few Tasmotized lamp switches, when I push the “ALL_OFF” button near the main door, before exiting the apartment).
When I trigger for example command A8-OFF, the openhab log says:
2020-04-13 19:38:00.705 [INFO ] [.binding.cm11a.internal.X10Interface] - cm11a received a command but the transmission didn’t include an address.
This kind of information seems useless and I don’t know if it’s because of the binding itself or because I’m in France and I’m using a cm12F serial interface (it should be compliant 100% to cm11a protocol).
When I trigger for example an ALL_UNITS_OFF command, the openhab log says:
2020-04-13 19:38:26.182 [WARN ] [.binding.cm11a.internal.X10Interface] - cm11a received the command: ALL_UNITS_OFF. This command is ignored by this binding.
In this case I have a command which is well recognized but I cannot find any way to make a system warning trigger anything! Is it technically possible ?
Has anybody a clue on how I could achieve my little goal ?!?
Any help would be greatly appreciated
V.
PS I already tried with cron and bash ( via tail command ) to parse the log file and trigger actions with :
openhab-cli console smarthome:send
but to avoid multiple triggers I have to delete from the log the WARN events, after the command execution, and then, unless I restart OH2 service ( I don’t have any clue why! ) I cannot get the WARN updates from the cm11a binding any more ( despite all continues to work correctly ).
