Java Runtime Environment: included in openHABian v1.4.1
openHAB version: 2.4.0-1
Issue of the topic:
When I send any ColorTemperature value, it’s always return back to value |0|. So, I’m not able to use current ColorTemperature value in other part of home automation configuration. See attached log file. Bulb model: Aeotec LED Bulb 6 Multi-White [ZWA001]
Hi Bruce, Yep, I tried to exclude, factory default and include again. Issue still persist.
When I send value 0, light is Cool. When I send value 100 or 50 light is changed to Warm, but value is reset back to 0 (light is still Warm). I wanna to preserve last sended value.
2019-11-09 20:22:17.152 [ome.event.ItemCommandEvent] - Item 'ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature' received command 0
2019-11-09 20:22:17.169 [nt.ItemStatePredictedEvent] - ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature predicted to become 0
2019-11-09 20:22:24.297 [ome.event.ItemCommandEvent] - Item 'ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature' received command 0
2019-11-09 20:22:24.315 [nt.ItemStatePredictedEvent] - ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature predicted to become 0
2019-11-09 20:22:27.076 [ome.event.ItemCommandEvent] - Item 'ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature' received command 50
2019-11-09 20:22:27.081 [nt.ItemStatePredictedEvent] - ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature predicted to become 50
2019-11-09 20:22:27.096 [vent.ItemStateChangedEvent] - ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature changed from 0 to 50
2019-11-09 20:22:27.408 [vent.ItemStateChangedEvent] - ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature changed from 50 to 0
2019-11-09 20:22:32.747 [ome.event.ItemCommandEvent] - Item 'ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature' received command 100
2019-11-09 20:22:32.764 [nt.ItemStatePredictedEvent] - ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature predicted to become 100
2019-11-09 20:22:32.778 [vent.ItemStateChangedEvent] - ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature changed from 0 to 100
2019-11-09 20:22:33.099 [vent.ItemStateChangedEvent] - ZWaveNode002ZWA001Bulb6MultiWhite_ColorTemperature changed from 100 to 0
ok… sorry… then… who cares? it works right?
If you have some use case where you want to know what the last set value was, as Bruce suggested, perhaps write it to a dummy item
So I guest this is the ‘standard’ behavior and the bulb is not defective? I can see your sight map not reflecting the current state of the bulb as a problem yes. I guess an unbound items with the value written to it each time it changes is your only choice. Here is a thread where Rich explains unbound objects
