Combined tooltip for aggregated and non-aggregated data in chart
I have created the following chart, that combines some aggregated data (the bar charts) and some normal data (the line charts) in one diagram. It is working fine, except that the bar chart values do not appear in the tooltip. How can I get them in there?
  chartType: day
  period: D
  label: PV Ertrag
  sidebar: true
slots:
  grid:
    - component: oh-chart-grid
        includeLabels: true
  xAxis:
    - component: oh-time-axis
        gridIndex: 0
        alignTicks: true
    - component: oh-category-axis
        gridIndex: 0
        categoryType: day
        weekdayFormat: default
        monthFormat: default
        alignTicks: true
  yAxis:
    - component: oh-value-axis
        gridIndex: 0
        max: "20000"
        position: left
        alignTicks: true
        min: "-20000"
        gridIndex: 0
        max: "20000"
        position: left
        alignTicks: true
        min: "-20000"
        inverse: true
        show: false
        gridIndex: 0
        max: "20"
        alignTicks: true
        min: "-20"
        gridIndex: 0
        max: "20"
        show: false
        alignTicks: true
        min: "-20"
        inverse: true
        gridIndex: 0
        min: "0"
        max: "0.6"
        offset: 80
        alignTicks: true
  series:
    - component: oh-time-series
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: line
        item: Kaco_Inverter_Power
        lineStyle:
          width: 1
        name: String 1 Power
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: line
        item: Kaco_Inverter_String_1_Power
        stack: production
        areaStyle: {}
        lineStyle:
          width: 0
        name: String 2 Power
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: line
        item: Kaco_Inverter_String_2_Power
        stack: production
        areaStyle: {}
        lineStyle:
          width: 0
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 1
        type: line
        item: Tibber_Pulse_powerTotal
        lineStyle:
          width: 1
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 4
        type: line
        item: TibberAPI_CurrentTotalPrice
    - component: oh-aggregate-series
        gridIndex: 0
        xAxisIndex: 1
        yAxisIndex: 2
        type: bar
        item: Kaco_Inverter_Total_Export
        dimension1: hour
        aggregationFunction: diff_last
        barGap: -100%
        barCategoryGap: 80%
        label:
          show: true
          position: bottom
          offset:
            - 0
            - 20
        z: 4
        gridIndex: 0
        type: bar
        item: energySelfConsumptionTotal
        dimension1: hour
        stack: consumption
        xAxisIndex: 1
        yAxisIndex: 2
        barGap: -100%
        barCategoryGap: 80%
        z: 4
        gridIndex: 0
        xAxisIndex: 1
        yAxisIndex: 2
        type: bar
        item: Tibber_Pulse_energyExportTotal
        dimension1: hour
        stack: consumption
        barGap: -100%
        barCategoryGap: 80%
        z: 4
        gridIndex: 0
        xAxisIndex: 1
        yAxisIndex: 3
        type: bar
        item: Tibber_Pulse_energyImportTotal
        dimension1: hour
        barGap: -100%
        barCategoryGap: 80%
        z: 4
  tooltip:
    - component: oh-chart-tooltip
        confine: true
        smartFormatter: true
        show: true
        trigger: axis
  legend:
    - component: oh-chart-legend
        bottom: 3
        type: scroll
  dataZoom:
    - component: oh-chart-datazoom
        type: inside
  toolbox:
    - component: oh-chart-toolbox
        show: true
        presetFeatures:
          - saveAsImage
          - dataView
          - dataZoom
        top: top
        left: left
I haven’t done this sort of formatting before so I can’t say exactly. I’m not even 100% sure this is possible. But, the charts are based on apache echarts and you can find the docs for the tooltip formatter here:
It is possible to send functions to the tooltip formatter as you can see in this example:
But whether or not you can append other data, I don’t know.
It’s quite awesome what you have achieved with those chart components but I don’t think what you ask is possible right now, but we never know:
there are a lot of options you can use: Documentation - Apache ECharts
most of them you can apply to the openHAB components!
Got it working!
Had to remove smartFormatter: true from the tooltip declaration.
