Hello!
I am trying to get a JSON and Javascript incoming transformation to run.
If I get the mqtt message 1 on the topic i expect to get 0.2 in the item.
The result now is that I get 1 on the item after receiving the message and the error message:
2020-07-05 20:25:20.257 [WARN ] [t.generic.ChannelStateTransformation] - Transformation service JS for pattern counter_precipitation.js not found!
I have both transformations installed.
It was working before but I did some modifications and I can’t figure out how to get it to run again.
- Platform information:
- Hardware: _CPUArchitecture/RAM/storage_RPi4 4GB
- openHAB version:2.5.6.2
example mqtt message
{"Time":"2020-07-05T20:06:20","Switch1":"ON","COUNTER":{"C1":1},"BME280":{"Temperature":23.4,"Humidity":60.1,"DewPoint":15.2,"Pressure":994.6},"BH1750":{"Illuminance":0},"PressureUnit":"hPa","TempUnit":"C"}
thing
Type number : raingauge "Niederschlagmesser" [stateTopic="C-BoilerRoom/tele/SENSOR", transformationPattern="JSONPATH:$.COUNTER.C1∩JS:counter_precipitation.js"]
item
Number:Length OU_Garden_Rain_Gauge "Niederschlag total [%.1f mm]" <rain> (OU_Garden, Weather) {channel="mqtt:topic:mosquitto:cboilerroom:raingauge"}
(function(i) {
if (isNaN(i)) {
return (i);
return(i * 0.2);
}) (input)
