Hi All,
after having lost a few hours to install cometVisu on my synology openhab2 installation I decided to share the final solution:
- Install addons from Paper UI : CometVisu BackEnd, PHP support for CometVisu
- Change permissions to the config file : sudo chmod 777 /volume1/homes/openhab/conf/services/cometvisu.cfg
- Edit cometvisu.cfg and change : webFolder=/volume1/homes/openhab/userdata/CometVisu/src
- create the client dir :mkdir /volume1/homes/openhab/userdata/CometVisu/
- Change permissions to the folder : sudo chown openhab:users /volume1/homes/openhab/userdata/CometVisu/
- Go to the root web page of openhab (:8080) and select CometVisu
- Set the same path int the text box (/volume1/homes/openhab/userdata/CometVisu/src) , flag autodownload and Install
This should work.
Enjoy
