Hello
I am running a ComfoAir 200 with integrated heater and frost protection.
The communication is done with ComfoAir Binding trough a serial connection (no separate control panel).
Till now everything looked good and working fine.
Now in the cold days I checked the frost protection and heater function.
My problem now is that the electrical heater does not work.
I saw that there are some values in the configuration for the heater but the are read only. So I can not give a specific value to heaterTargetTemperature.
| Heater Values | |||||
| heater#heaterPower | Number | Heater Power | Heater power value | true | yes |
| heater#heaterPowerI | Number | Heater Power I-parameter | Heater power I-parameter value | true | yes |
| heater#heaterTargetTemperature | Number:Temperature | Heater Target Temperature | Target temperature of the heater | true | yes |
Maybe someone can share some details how the heater-function is controlled with OH3?
At the moment I am running the newest milestone build openHAB 3.2.0.M5.
Thank you in advance. BR Sebastian
