I am currenctly using OH3.1 and my main control is using habpanel through a VPN.
However, I would like to use the mainUI with custom widgets for my family via myopenhab.org (no vpn hassle for them).
I read a few posts about having issues accessing mainUI remotely
but it seems to work for me.
However, accessing it using Safari (iphone) is not really comfortable, because:
The UI in 3.1 tries to use the Credentials Management API to help you save your credentials locally in the browser especially when you add the main UI (https://home.myopenhab.org) to your home screen when using myopenHAB. This should be supported in mobile Safari as of version 13.
If you meet these requirements and have trouble getting access I’m interested in whatever debug logs you can provide. If you can make screenshots or videos of what happens this could help.
Thank you, Yannick.
I will check it out and give it a try.
One more question though.
For my family members I need to share the credentials to myopenhab. org (before the user login) or is there a way around it
(just to keep things easier safer with our kids ;-)?
The credentials to myopenHAB are separate from your credentials to openHAB proper.
You could share your myopenHAB credentials to your family but unless they log in as an admin once they get access past the cloud proxy to the instance (by default, as anonymous guests) they won’t have access to the admin section and also parts of the UI that you’ve hidden with the visibleTo config parameter.
So, this means in other words, that after the initial login (via myopenhab admin), the various user accounts won’t have the access to the admin functions anymore, because the connection is automatically tunneled through to the mainUI!?
Visit Biometric Authentication with Passkeys - Demo & Code with your phone, and look for “Supported” alongside navigator.credentials under the “support in your browser” section. They say iOS Safari >= 14 supports it now, but I just tested with BrowserStack and it doesn’t appear to be the case (it says “Not supported”) - if so, you’re out of luck. If it reports it as supported, maybe try the demo form and see if it actually works.
I have tested some iOS browsers like this with no luck:
(the procedure below was done without the user login at mainUI - so it’s about the general login at home.myopenhab.org only (so far)
edge:
Login was successful on myopenhab.org.
Changing to home.myopenhab.org showed the mainUI properly.
No option to store the credentials.
Using the browser later showed the login dialogue again
Later on I was able to make use of the previously stored usr/pwd (by Safari or another browser).
firefox
I was able to store the credentials.
Using the browser later showed “unauthorized” when opening home.myopenhab.org
So it’s required to login at myopenhab.org again (fortunately I was able to select the credentials from the stored user/pwd DB).
firefox provides the function to store usr/pwd manually. Unfortunately this does not help with the “unauthorized” issue. (Which is most likely related to the mainUI login credentials)
DuckDuckGo
Quite similar to firefox
Using the browser later showed “unauthorized” opening home.myopenhab.org
Although the manual login is still not user friendly …
Chrome & Opera
Later I was able to select the credentials from the stored user/pwd DB to log in to home.myopenhab.org
Chrome: NO, Opera: YES
General:
Just edge was able to identify and suggest the right usr/PWD on top of the DB screen (which makes it easier than scrollung through the DB) Question:
Shouldn’t the browser be able to link the stored usr/pwd of myopenhab.org to home.myopenhab.org?
The required mainUI login seems to have problems on all platforms.
Providing the user login for mainUI leads to “unauthorized”.
I assume, that the myopenhab login gets in conflict with the mainUI credentials (different credentials for the same website!?)
So, I am not sure if there is an option to use mainUI remotely (comfortably) unless the credentials stuff is implemented on iOS properly
