Command 'an' is not supported by type 'OnOffValue': No enum constant
i am using the homeassistant mqtt plugin to get the values from my esp-ems Gateway. i only use a little selection of mqtt channels. But my log is flooded with warnings like this:
Command ‘aus’ from channel ‘mqtt:homeassistant_ems_2Desp_2Dthermostat:901628e3:ems_2Desp_2Dthermostat:thermostat_5Fhc1_5Fswitch_2Don_5Foptimization#switch’ not supported by type ‘OnOffValue’: No enum constant org.openhab.core.library.types.OnOffType.aus
fo the items i use, i created a map. But all the warnings will be generated by cahnnels that i dont use/created. its created by the homeassistan automatism. is it possible to create a gloabl mapping of
an->ON
aus->OFF
Thanks :slight_smile:
You have to map the values in the mqtt Channel onValue: an and offValue: aus.
MAP transformation is one way, it highly depends on where you did the configuration.
A Channel (e.g, mqtt generic thing channel) has incomming value transformation and outgoing value transformation, so you’ll have to define both directions separate.
A link profile afaik is one way, only Channel to Item will be covered by transformation, not Item to Channel.
Finally, a transformation in the label part will only affect displaying the status, but not the status itself (i.e. the status will stay the same as without transformation)
