Is it possible to run Etcher via the command line? Give the program the location of the image and the drive of the micro SD card?
I am trying to script the whole setup of our Raspberry Pi set up to make life easier for my Production.
Maybe this one here helps: Link
Kind of similar question, even in wording
If you are running the SD card burning from a Linux or Mac I think you can burn an image using the dd
command. On Windows there is a small chance that CYGWIN or MINGWIN might support dd
but it’s a really low level command so maybe not. There appears to be a command line version of WinDiskImager which might be an option as well.
