- Platform information:
- Hardware: x86_64 Atom/4GB/20GB
- OS: Ubuntu Linux 20.04
- Java Runtime Environment: OpenJDK 11.0.10
- openHAB version: 3.1.0
- Issue of the topic: Sending updates from a rule script to a ZigBee Color bulb does not cause any change in the bulb state
I have the following script (and many variations besides) which does not actually allow me to toggle between Black(OFF) and Red.
import org.openhab.core.library.types.*
import static org.openhab.core.model.script.actions.BusEvent.*
import org.slf4j.LoggerFactory
def logger = LoggerFactory.getLogger("org.openhab.core.automation.examples")
def hsb = itemRegistry.getItem("DevenColorBulb_Color").getStateAs(HSBType.class).toString()
logger.info("${hsb.getClass().getCanonicalName()}: ${hsb}")
if (!hsb.contentEquals("0,100,100")) {
logger.info("Sending: Red")
postUpdate("DevenColorBulb_Color", "0,100,100")
} else {
logger.info("Sending: Black")
postUpdate("DevenColorBulb_Color", "0,100,0")
I can see from the log output that the correct commands are being sent, but the bulb almost never changes. The only time it DOES seem to change is if I manually change the color from habpanel and then run the rule script.
I have many similar rules for Z-Wave devices (Switches and Dimmers) and they work reliably. What am I doing wrong here?
Thanks in advance for any help!
