Command substitution: ignored null byte in input
Hello All,
I am a newbie to OpenHabian.
Trying to setup OpenHabian 1.4.1 on RPI 3 Model B+.
Etched the image on SD card (32gb) and inserted to rpi.
I am seeing the following warning over and over again and nothing happens.
“first-boot.sh line 56: warning: Command substitution: ignored null byte in input”
Please help.
Thank you.
Is it a new SD card?
Try again, new download, new flash
Yes it is a new SD card.
Did the new flash multiple times, no luck.
Also tried with an old SD card (16gb), same issue.
Anything else i can try?
Thanks.
Did you try downloading the image again?
Yes.
Downloaded 3 times, flashed it 4-5 times. (2 different SD cards).
Same error.
Also tried with my old RPI 1 B+.
Seeing the same error.
