Since few days ago I am having an issue that the commands via the Main UI or even via Google and zigbee buttons are not executing.
If for example I try to switch off the light office (shelly dimmer) in the log I see for example that the command is executed correctly, but the light stays on:
2024-05-04 23:51:15.460 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'LightOffice' received command 0
2024-05-04 23:51:15.461 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LightOffice' predicted to become 0
2024-05-04 23:51:15.461 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'LightOffice' updated to 0
2024-05-04 23:51:15.461 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LightOffice' changed from 100 to 0
2024-05-04 23:51:15.461 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'grpLightBulbs' updated to ON through LightOffice
2024-05-04 23:51:15.462 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'itmLightOfficeTimerOverride' received command OFF
Simmilar for the light Hall (zigbee via deconz)
2024-05-04 23:54:22.536 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'LightHall' received command 70
2024-05-04 23:54:22.537 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LightHall' predicted to become 70
2024-05-04 23:54:22.538 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'LightHall' updated to 70
2024-05-04 23:54:22.538 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LightHall' changed from 0 to 70
2024-05-04 23:54:22.539 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'grpLightBulbs' updated to ON through LightHall
2024-05-04 23:54:22.733 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'LightHall' received command 100
2024-05-04 23:54:22.734 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LightHall' predicted to become 100
2024-05-04 23:54:22.735 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'LightHall' updated to 100
2024-05-04 23:54:22.736 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LightHall' changed from 70 to 100
also the my Zwave Fibaro shutters don’t move.
I need to restart the service to fix everything, but after some time it all stops
If I look in the things, all those devices are online and the values are getting updated, even the trending works for example.
I am running openHAB 4.1.2 Release Build on Ubuntu 22.04.04 LTS
I have no idea what to look for in the logs to identify the problem.
Any suggestions would be welcome
