Since upgrading to openHAB 3.3.0 I cannot establish a connection to my Conbee 2 / deconz.
I’m running openHAB on a Rasperry (openHABian) with UI on port 8080. Deconz is running on the same decive on port 8090.
● deconz.service - deCONZ: ZigBee gateway -- REST API
Loaded: loaded (/lib/systemd/system/deconz.service; disabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/deconz.service.d
└─override.conf
Active: active (running) since Mon 2022-08-22 15:40:31 CEST; 18min ago
Main PID: 11884 (deCONZ)
Tasks: 4 (limit: 4915)
CGroup: /system.slice/deconz.service
└─11884 /usr/bin/deCONZ -platform minimal --http-port=8090
Deconz Web UI is working, just openHAB is not able to establish a connection.
I’ve tried restarting, reconnecting, with and without API key. Without success until now. See the following log output.
[INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:00212E075414' changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): Error while connecting: org.eclipse.jetty.websocket.api.UpgradeException: Failed to upgrade to websocket: Unexpected HTTP Response Status Code: 200 OK
[INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:00212E075414' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: org.eclipse.jetty.websocket.api.UpgradeException: Failed to upgrade to websocket: Unexpected HTTP Response Status Code: 200 OK to OFFLINE (COMMUNICATION_ERROR): Error while connecting: Destroyed container cannot be restarted
[WARN ] [nternal.netutils.WebSocketConnection] - Websocket$1661174781205-1 trying to re-connect while still disconnecting
[INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:00212E075414' changed from OFFLINE (CONFIGURATION_PENDING): Waiting for configuration to OFFLINE (COMMUNICATION_ERROR): Error while connecting: Destroyed container cannot be restarted
[INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:00212E075414' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: Destroyed container cannot be restarted to OFFLINE (CONFIGURATION_PENDING): Requesting API Key
[INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:00212E075414' changed from OFFLINE (CONFIGURATION_PENDING): Requesting API Key to OFFLINE (CONFIGURATION_PENDING): Waiting for configuration
[INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:00212E075414' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: org.eclipse.jetty.websocket.api.UpgradeException: Failed to upgrade to websocket: Unexpected HTTP Response Status Code: 200 OK to OFFLINE (COMMUNICATION_ERROR): Error while connecting: null
Thing configuration is set up to use 8090 as http and websocket port. What am I missing? Any ideas?
facing the same here.
Although all these errors are thrown and the bridge is tagged “ERROR: COMM”, it seems to work!? The lights appeared in my inbox and I am able to control them, despite the error.
I am using TrueNAS Scale with truecharts.org, deconz and openhab are running in different pods (if this is the right term, used to use pure docker before).
snippet from debug.log (you’ll find a longer one in the attachement deconz.log (76.4 KB)
2022-09-03T15:09:00.994198336Z 17:09:00.993 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:6f0a0e82dd' changed from UNINITIALIZED to INITIALIZING
2022-09-03T15:09:00.995380081Z 17:09:00.995 [DEBUG] [internal.handler.DeconzBridgeHandler] - Start initializing bridge deconz:deconz:6f0a0e82dd
2022-09-03T15:09:11.025007578Z 17:09:11.023 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:09:11.029053544Z 17:09:11.028 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:6f0a0e82dd' changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): Error while connecting: java.net.ConnectException: Connection refused
2022-09-03T15:09:21.030831638Z 17:09:21.030 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:09:21.036621295Z 17:09:21.036 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:6f0a0e82dd' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: java.net.ConnectException: Connection refused to OFFLINE (COMMUNICATION_ERROR): Error while connecting: null
2022-09-03T15:09:31.036550195Z 17:09:31.035 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:09:41.039585800Z 17:09:41.038 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:09:51.040944772Z 17:09:51.040 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:10:01.042261307Z 17:10:01.041 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:10:11.044038385Z 17:10:11.043 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:10:21.045084031Z 17:10:21.044 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:10:31.046159103Z 17:10:31.045 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:10:41.047344923Z 17:10:41.046 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:10:51.048344266Z 17:10:51.047 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:11:01.049408070Z 17:11:01.048 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:11:11.050868837Z 17:11:11.050 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:11:21.051928252Z 17:11:21.051 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:11:31.052995429Z 17:11:31.052 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:11:41.054027008Z 17:11:41.053 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:11:51.055041953Z 17:11:51.054 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:12:01.056127802Z 17:12:01.055 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:12:11.057231431Z 17:12:11.056 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:12:21.058387340Z 17:12:21.057 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:12:31.059294067Z 17:12:31.058 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:12:31.060774519Z 17:12:31.060 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:6f0a0e82dd' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: null to OFFLINE (COMMUNICATION_ERROR): Error while connecting: java.net.ConnectException: Connection refused
2022-09-03T15:12:41.060980317Z 17:12:41.060 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:12:41.062751449Z 17:12:41.062 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:6f0a0e82dd' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: java.net.ConnectException: Connection refused to OFFLINE (COMMUNICATION_ERROR): Error while connecting: null
2022-09-03T15:12:51.062230020Z 17:12:51.061 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:13:01.063190080Z 17:13:01.062 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:13:11.064244391Z 17:13:11.063 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:13:21.065403556Z 17:13:21.064 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:13:31.065962379Z 17:13:31.065 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:13:41.067073025Z 17:13:41.066 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:13:51.067870933Z 17:13:51.067 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:14:01.003835881Z 17:14:01.003 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'deconz:daylightsensor:6f0a0e82dd:00212effff093c9401' to inbox.
2022-09-03T15:14:01.004025162Z 17:14:01.003 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'deconz:daylightsensor:6f0a0e82dd:00212effff093c9401' has been added.
2022-09-03T15:14:01.005710276Z 17:14:01.005 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'deconz:colortemperaturelight:6f0a0e82dd:847127fffe0a91f001' to inbox.
2022-09-03T15:14:01.006463197Z 17:14:01.006 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'deconz:colortemperaturelight:6f0a0e82dd:84fd27fffed1e48201' to inbox.
2022-09-03T15:14:01.008230601Z 17:14:01.007 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'deconz:lightgroup:6f0a0e82dd:1' to inbox.
2022-09-03T15:14:01.013139418Z 17:14:01.010 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'deconz:colortemperaturelight:6f0a0e82dd:847127fffe0a91f001' has been added.
2022-09-03T15:14:01.013247396Z 17:14:01.013 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'deconz:colortemperaturelight:6f0a0e82dd:84fd27fffed1e48201' has been added.
2022-09-03T15:14:01.013346538Z 17:14:01.013 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'deconz:lightgroup:6f0a0e82dd:1' has been added.
2022-09-03T15:14:01.068797103Z 17:14:01.068 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:14:11.070122617Z 17:14:11.069 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:14:21.071131114Z 17:14:21.070 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:14:31.072231030Z 17:14:31.071 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:14:41.073429027Z 17:14:41.072 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:14:51.074569152Z 17:14:51.074 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:15:01.075239783Z 17:15:01.075 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:15:01.076179155Z 17:15:01.076 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:6f0a0e82dd' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: null to OFFLINE (COMMUNICATION_ERROR): Error while connecting: java.net.ConnectException: Connection refused
2022-09-03T15:15:11.076454146Z 17:15:11.075 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:15:11.077782348Z 17:15:11.077 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:6f0a0e82dd' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: java.net.ConnectException: Connection refused to OFFLINE (COMMUNICATION_ERROR): Error while connecting: null
2022-09-03T15:15:21.077571397Z 17:15:21.077 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:15:21.079208184Z 17:15:21.078 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:6f0a0e82dd' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: null to OFFLINE (COMMUNICATION_ERROR): Error while connecting: java.net.ConnectException: Connection refused
2022-09-03T15:15:31.079178623Z 17:15:31.078 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:15:31.080460315Z 17:15:31.080 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:6f0a0e82dd' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: java.net.ConnectException: Connection refused to OFFLINE (COMMUNICATION_ERROR): Error while connecting: null
2022-09-03T15:15:41.080372256Z 17:15:41.079 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:15:51.081484460Z 17:15:51.080 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:16:01.082598704Z 17:16:01.082 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:16:11.083634300Z 17:16:11.083 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:16:21.085138157Z 17:16:21.084 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:16:23.023004138Z 17:16:23.022 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'deconz:colortemperaturelight:6f0a0e82dd:847127fffe0a91f001' has been removed.
2022-09-03T15:16:23.026116066Z 17:16:23.025 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:colortemperaturelight:6f0a0e82dd:847127fffe0a91f001' changed from UNINITIALIZED to INITIALIZING
2022-09-03T15:16:23.031920806Z 17:16:23.031 [DEBUG] [econzDynamicStateDescriptionProvider] - Cannot post event as EventPublisher is missing
2022-09-03T15:16:23.033908964Z 17:16:23.033 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:colortemperaturelight:6f0a0e82dd:847127fffe0a91f001' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE)
2022-09-03T15:16:28.776155141Z 17:16:28.775 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'deconz:colortemperaturelight:6f0a0e82dd:84fd27fffed1e48201' has been removed.
2022-09-03T15:16:28.779604426Z 17:16:28.777 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:colortemperaturelight:6f0a0e82dd:84fd27fffed1e48201' changed from UNINITIALIZED to INITIALIZING
2022-09-03T15:16:28.782390982Z 17:16:28.782 [DEBUG] [econzDynamicStateDescriptionProvider] - Cannot post event as EventPublisher is missing
2022-09-03T15:16:28.782804964Z 17:16:28.782 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:colortemperaturelight:6f0a0e82dd:84fd27fffed1e48201' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE)
2022-09-03T15:16:31.086272209Z 17:16:31.085 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:16:41.086895036Z 17:16:41.086 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:16:42.402365832Z 17:16:42.401 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LightPillarRight_Helligkeit' changed from NULL to 0
2022-09-03T15:16:42.402411489Z 17:16:42.402 [INFO ] [openhab.event.ItemUpdatedEvent ] - Item 'LightPillarRight_Helligkeit' has been updated.
2022-09-03T15:16:42.404407936Z 17:16:42.404 [INFO ] [openhab.event.ItemUpdatedEvent ] - Item 'LightPillarRight_Farbtemperatur' has been updated.
2022-09-03T15:16:43.320613280Z 17:16:43.319 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: LightPillarRight
2022-09-03T15:16:51.087860959Z 17:16:51.087 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:17:01.088945438Z 17:17:01.088 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:17:08.866101827Z 17:17:08.865 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LightPillar001_Helligkeit' changed from NULL to 0
2022-09-03T15:17:11.090104325Z 17:17:11.089 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:17:21.091117960Z 17:17:21.090 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:17:23.969573117Z 17:17:23.968 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'LightPillar002_Helligkeit' changed from NULL to 0
2022-09-03T15:17:31.092735816Z 17:17:31.092 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:17:41.093854165Z 17:17:41.093 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:17:51.094744339Z 17:17:51.094 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:17:51.097598651Z 17:17:51.096 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:6f0a0e82dd' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: null to OFFLINE (COMMUNICATION_ERROR): Error while connecting: java.net.ConnectException: Connection refused
2022-09-03T15:18:01.097905823Z 17:18:01.097 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:18:01.099778030Z 17:18:01.099 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:6f0a0e82dd' changed from OFFLINE (COMMUNICATION_ERROR): Error while connecting: java.net.ConnectException: Connection refused to OFFLINE (COMMUNICATION_ERROR): Error while connecting: null
2022-09-03T15:18:03.931269952Z 17:18:03.930 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'LightPillar001_Helligkeit' received command 16
2022-09-03T15:18:03.932066059Z 17:18:03.931 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LightPillar001_Helligkeit' predicted to become 0
2022-09-03T15:18:04.829793201Z 17:18:04.829 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'LightPillar001_Helligkeit' received command 0
2022-09-03T15:18:04.830094256Z 17:18:04.829 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'LightPillar001_Helligkeit' predicted to become 0
2022-09-03T15:18:11.100110055Z 17:18:11.099 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
2022-09-03T15:18:21.101376802Z 17:18:21.100 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect Websocket$1662217740991-1 to ws://deconz.ix-deconz.svc.cluster.local:10001
