I am looking for hints on how I could fix the below described issue that I face with a Homematic HG-HM-LC-Sw4-WM that a lately installed. I have two other Homematic devices in my environment that work properly. The new device is not working properly and when I check the logs I see that there is some kind of communication issue (na answer from device). What I did so far:
Removed the thing and added the thing again.
update/upgrade openHAB
reinstalled homegear
updated homegear
Nothing helped. So I set the debug level for Homematic to DEBUG. As I am not able to interpret the log myself it would be great if someone could give me a hint.
My environment:
Openhab = openHAB 2.4.0-1 (Release Build)
Homegear = 0.7.39-2773
Release = Raspbian GNU/Linux 8 (jessie)
Kernel = Linux 4.9.35-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
Wireless Module for Homematic = HM-MOD-RPI-PCB
06:30:14.898 [INFO ] [smarthome.event.ItemStateChangedEvent] - Hm1Ch1_2_State changed from OFF to ON
06:30:14.897 [DEBUG] [mematic.handler.HomematicThingHandler] - Received command 'ON' for channel 'homematic:HG-HM-LC-Sw4-WM:dcd1d685:PEQ1419156:2#STATE'
06:30:14.916 [DEBUG] [communicator.AbstractHomematicGateway] - Sending datapoint 'PEQ1419156:2#STATE' with value 'true' to gateway with id 'dcd1d685' using rxMode 'DEFAULT'
06:30:17.489 [DEBUG] [rnal.communicator.client.BinRpcClient] - BinRpcMessage socket failure, sending message again 1/1
06:30:20.072 [ERROR] [mematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
PEQ1419156:2
STATE
true
java.io.IOException: -100 No answer from device. (sending setValue()
PEQ1419156:2
STATE
true
at org.eclipse.smarthome.binding.homematic.internal.communicator.parser.RpcResponseParser.parse(RpcResponseParser.java:51) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:82) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:94) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:70) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.client.RpcClient.setDatapointValue(RpcClient.java:335) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.AbstractHomematicGateway$1.execute(AbstractHomematicGateway.java:686) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.misc.DelayedExecuter.start(DelayedExecuter.java:65) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:665) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:644) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.handler.HomematicThingHandler.sendDatapoint(HomematicThingHandler.java:307) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.handler.HomematicThingHandler.handleCommand(HomematicThingHandler.java:283) [198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor102.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at com.sun.proxy.$Proxy127.handleCommand(Unknown Source) [198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor101.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
