Who can assist me with a forum issue please?
i cant login ‘BigCol’ is my username
I looked at your profile and I don’t see anything unusual. Your account is not locked or staged or hidden or anything like that.
Based on the URL it looks like something failed with the oauth2 negotiation. I couldn’t say what but it’s not something I can fix as a moderator. It’ll take someone from @staff to fix, if it is indeed a problem on our side and not on Google’s side.
Have you tried multiple browsers or at least restarting your browser?
Are you accessing the forum through a web proxy?
Issue exists on both Chrome and Edge (I guess Edge is built on chrome these days?) and on 2 different machines.
I’m not using a proxy
Colin
any ideas please guys?
What happens when you try to log in using your phone on mobile data?
Did you try:
same issue on mobile whether on wifi or 4G. So that’s 3 devices now all with the same issue.
Yes to all ![]()
i seem to have 2 problems,
when i try to login using my username BigCol i get ‘Unknown Error’
When i try and use the google authentication i get the error in my first post
using this new account ‘bbh’ i can login.
I can also login using my Google Account ‘domestic@blancabeachhouse.com’
So this doesn’t look like an environment issue but an account issue.
Hope this extra info helps.
Colin
I have found a PC that i’m logged in on, and is working. i bet if I log out i wont be able to log in again, i expect i would get the errors above.
Issue resolved. I removed Openhab from the google Authenticated Apps list.
Then logged in successfully.
