Comparing Number Items using percentage with character "%" [Deconz]
i am currently programing a rule which involves comparing a humidity sensor reading optained from the Deconz binding to a threshold.
Logging the Item state with
logInfo("Info", deconz_humiditysensor_414706f1_humidity)
yields the following output
deconz_humiditysensor_414706f1_humidity (Type=NumberItem, State=58.36 %, Label=Humidity, Category=null)
The problem i am facing is, that comparing the item state against a threshold does not work, due to the appended “%” character in the state of the item.
E.g. the following does not work:
if(deconz_humiditysensor_414706f1_humidity.state>=90)
     // do this
}else{
    // do that
The workaround i have found looks like this:
val DecimalType humidityThresh= new DecimalType(90)
var DecimalType sensorReading = new DecimalType(deconz_humiditysensor_414706f1_humidity.state.toString().replace("%","").replace(" ",""));
if(sensorReading >=humidityThresh)
     // do this
}else{
    // do that
Those skilled in the art of openhab rule making surely know a simpler way, right?
Welcome to UoM, units of measurement.
Extract the numeric value
if ( (deconz_humiditysensor_414706f1_humidity.state as QuantityType<Number>).doubleValue >= 90) {
or I think to compare in units
if ( deconz_humiditysensor_414706f1_humidity.state >= 90 | "%" ) {
Thank your for the quick answer.
Is there any guide or docu describing how to use QuantityType(s) within rule scripts in gerneral.
Did a quick search and couldn’t find any!
BR,
Thomas
