I’m trying to compare temperature on my virtual Item vs Heater item. I’m not sure if both items have to have exactly same Class ?
I picked same Type Number:Temperature. One has class Setpoint other just Point.
One has Semantic Property None with the second item I picked Temperature.
When I will run below piece of code with Logs I see that “°C” is being printed but I don’t know why comparison fails.
Z_waveThing_SetPoint_Name = Z_waveThingName + '_Setpointheat'
Z_waveThing_SetPoint_Value = itemRegistry.getItem(Z_waveThing_SetPoint_Name).getState();
VirtualThingName = ListOfThings[i].virtual_item;
Desired_SetPoint_Name = VirtualThingName + '_Desired_SetPoint';
Desired_SetPoint_Value = itemRegistry.getItem(Desired_SetPoint_Name).getState();
logger.info((['| Validate_Heater_Mode | Items: ', Z_waveThingName, ' : ', VirtualThingName].join('')));
logger.info((['| Validate_Heater_Mode | SetPoint: ', Z_waveThing_SetPoint_Value, ' : ', Desired_SetPoint_Value].join('')));
if (Z_waveThing_SetPoint_Value != Desired_SetPoint_Value) {
logger.info((['| Validate_Heater_Mode | Synchronise SetPoint_Values mode : ', SyncMode].join('')));
logger.info((['| Validate_Heater_Mode | SetPoint - z_wave : ', Z_waveThing_SetPoint_Value, ' Desired: ', Desired_SetPoint_Value, ' |'].join('')));
The problem is I’m not able to compare the temperatures of those two items.
2021-02-01 20:24:15.762 [INFO ] [org.openhab.rule.2c7096d114 ] - | Validate_Heater_Mode | SetPoint: 23 °C : 23.0 °C
2021-02-01 20:24:15.764 [INFO ] [org.openhab.rule.2c7096d114 ] - | Validate_Heater_Mode | Synchronise SetPoint_Values mode : VIRTUAL_HEATER
2021-02-01 20:24:15.767 [INFO ] [org.openhab.rule.2c7096d114 ] - | Validate_Heater_Mode | SetPoint - z_wave : 23 °C Desired: 23.0 °C |
Heater config:
Virtual Heater:
