i have a exportet XML File from Chris Jackson Zwave Database. I want to compile it with eclipse and import it in my Openhab2 System. I google, but dont find a manual how to do this. All i find is how to compile programms for openhab.
The xml is compiled in with the binding. There is a method to do this on the forum somewhere, I haven’t done it for OH2 yet since I just moved over recently. But it may already be in the snapshot binding, have you tried that? You can see the link to the github for the binding which will allow you to look at the xml for the device and if it’s been updated in there you can grab the snapshot from the second link.
Ok, just some more Informations. I want to develop some Devices by myself with the Zuno (zwave). So i often change something and i must change the database from Chris Jackson and wait for the next snapshot. This spend a lot of time. So Chris said i must change the XML file and then compile it for OH2. I google but i dont find a tip how to compile the XML file with eclipse and what i must do after then.
I don’t know how familiar you are with this type of thing but I will link to what I have found. I have not set this up for OH2 yet but I did this for OH1 and it worked great for me to adjust the xml files and recompile the binding.
