rlkoshak
(Rich Koshak)
October 5, 2020, 3:47pm
21
It’s also possible to run it in a shell if you pass the command to a shell. For example:
val myText = "bash -c 'sudo -u openhab /usr/bin/curl... | /usr/bin/jq \..."
Though I would still recommend using a shell script like you have done already. As mentioned, getting the quotes right and all the escaping becomes challenging. But I wanted to mention that it is possible to run commands in a shell so you can get pipes and redirects and such.
NOTE: There is no reason to sudo -u openhab, it’ll already be running as user openhab.
LaurentiuB
(Laurentiu B)
October 6, 2020, 11:30am
22
I don’t know how to use your example.
I tried
rule "Test DSL rule"
System started
logWarn("Rules", "Test: Start")
var current_label
val state_description_options = WebOS.stateDescription.options
state_description_options.forEach[option|
if (option.value == WebOS_state.state.toString()) {
current_label = option.label
logWarn("Rules", "current_label: '{}'", current_label)
logWarn("Rules", "Test: End")
where WebOS is like this, but with a lot more value/ label lines
"link": "http://209.0.0.0:8080/rest/items/LG_TV0_Channel",
"state": "3_24_57_57_212_321_1",
"stateDescription": {
"pattern": "%s",
"readOnly": false,
"options": [
"value": "3_14_56_56_103_320_1",
"label": "56 - Travel"
"value": "3_24_57_57_212_321_1",
"label": "57 - Travel Channel HD"
"commandDescription": {
"commandOptions": [
"command": "3_14_56_56_103_320_1",
"command": "3_24_57_57_212_321_1",
"editable": false,
"type": "String",
"name": "LG_TV0_Channel",
"label": "Channel",
"tags": [
"groupNames": [
And WebOS_state is 3_24_57_57_212_321_1 so the output should be “57 - Travel Channel HD”
log says
14:20:14.218 [INFO ] [smarthome.event.ItemStateChangedEvent] - WebOS_state changed from 3_12_95_95_101_412_1 to 3_24_57_57_212_321_1
14:20:15.020 [WARN ] [.eclipse.smarthome.model.script.Rules] - Test: Start
14:20:15.023 [INFO ] [g.eclipse.smarthome.model.script.test] - WebOS_state received: 3_24_57_57_212_321_1
14:20:15.072 [WARN ] [.eclipse.smarthome.model.script.Rules] - current_label: '{}'
14:20:15.082 [WARN ] [.eclipse.smarthome.model.script.Rules] - Test: End
5iver
(Scott Rushworth)
October 6, 2020, 1:32pm
23
How about this?
Item WebOS_state changed
logWarn("Rules", "WebOS_state changed: {}", WebOS_state.state)
var current_label
val state_description_options = WebOS_state.stateDescription.options
LaurentiuB
(Laurentiu B)
October 6, 2020, 1:40pm
24
Still not working
16:38:57.942 [WARN ] [.eclipse.smarthome.model.script.Rules] - Test: Start
16:38:57.965 [WARN ] [.eclipse.smarthome.model.script.Rules] - WebOS_state changed: 3_3_22_22_233_153_1
16:38:57.982 [WARN ] [.eclipse.smarthome.model.script.Rules] - current_label: '{}'
16:38:57.994 [WARN ] [.eclipse.smarthome.model.script.Rules] - Test: End
rossko57
(Rossko57)
October 6, 2020, 2:18pm
25
I don’t think you want the quotes around the curly braces in the logInfo
LaurentiuB
(Laurentiu B)
October 6, 2020, 2:39pm
26
I have removed the quotes
logWarn("Rules", "current_label: {}", current_label)
log is the same
17:37:38.854 [WARN ] [.eclipse.smarthome.model.script.Rules] - current_label: {}
5iver
(Scott Rushworth)
October 6, 2020, 3:00pm
27
Try some more logging…
var current_label
logWarn("Rules", "state_description_options: {}", state_description_options)
logWarn("Rules", "option: {}", option)
rossko57
(Rossko57)
October 6, 2020, 3:03pm
28
That’s a bit curious; in a logInfo() curly braces get replaced with the object following. Importantly, the curly braces do not themselves appear in the output.
Looks like that doesn’t work with logWarn.
Let’s spell it out
logInfo(“test”, "result " + current_label.toString)
5iver
(Scott Rushworth)
October 6, 2020, 3:08pm
29
This…
logWarn("Rules", "'{}'", null)
… logs…
2020-10-06 11:06:55.079 [WARN ] [org.eclipse.smarthome.model.script.Rules] - '{}'
And this…
logWarn("Rules", "'{}'", "test")
… logs this…
2020-10-06 11:10:23.548 [WARN ] [org.eclipse.smarthome.model.script.Rules] - 'test'
There is no issue using single quotes around your curly brackets, but when your logging null, it looks odd.
LaurentiuB
(Laurentiu B)
October 6, 2020, 3:21pm
30
18:20:16.979 [WARN ] [.eclipse.smarthome.model.script.Rules] - state_description_options: []
18:20:17.358 [INFO ] [smarthome.event.ItemStateChangedEvent] - WebOS_state changed from 3_12_92_92_101_390_1 to 3_3_93_93_233_401_1
18:20:17.359 [WARN ] [.eclipse.smarthome.model.script.Rules] - current_label: {}
18:20:17.379 [WARN ] [.eclipse.smarthome.model.script.Rules] - Test: End
5iver
(Scott Rushworth)
October 6, 2020, 3:24pm
31
That’s missing one of the logs… maybe two
What Channel is WebOS_state linked to? Maybe provide all of your Harmony Hub Item definitions?
Never mind… I just scrolled up. It looks like this rule shoujld be using the LG_TV0_Channel Item instead of WebOS_state.
LaurentiuB
(Laurentiu B)
October 6, 2020, 3:40pm
32
This is the item definition
String LG_TV0_Channel "Channel [%s]" { channel="lgwebos:WebOSTV:tv1:channel" }
Number LG_TV0_ChannelDummy "ChannelUpDown"
String LG_TV0_Application "Application [%s]" { channel="lgwebos:WebOSTV:tv1:appLauncher"}
String LG_TV0_Application_Name "Application [%s]"
String WebOS "JSON [%s]" {http="<[WebOS:1000:JSONPATH($..*)]"}
String WebOS_state "State [%s]" {http="<[WebOS:1000:JSONPATH($.state)]"}
String WebOS_label "Channel [%s]"
And this is the log
18:37:34.919 [WARN ] [.eclipse.smarthome.model.script.Rules] - Test: Start
18:37:34.916 [INFO ] [smarthome.event.ItemStateChangedEvent] - WebOS changed from ["http://209.12.145.41:8080/rest/items/LG_TV0_Channel", "3_17_94_94_202_410_1", "{pattern=%s, readOnly=false, options=[{"value":"0_2_1_0_2_0_0","label":"1 - S 02"},{"value":"0_4_3_0_4_0_0","label":"3 - S 03"},{"value":"0_6_5_0_6_0_0","label":"5 - S 04"},{"value":"0_8_7_0_8_0_0","label":"7 - S 05"},{"value":"0_10_9_0_10_0_0","label":"9 - S 06"},{"value":"0_12_11_0_12_0_0","label":"11 - S 08"},{"value":"0_14_13_0_14_0_0","label":"13 - S 09"},..........................and more lines
18:37:34.942 [WARN ] [.eclipse.smarthome.model.script.Rules] - WebOS_state changed: 3_3_93_93_233_401_1
18:37:35.346 [WARN ] [.eclipse.smarthome.model.script.Rules] - state_description_options: []
18:37:35.372 [WARN ] [.eclipse.smarthome.model.script.Rules] - current_label: {}
18:37:35.388 [WARN ] [.eclipse.smarthome.model.script.Rules] - Test: End
LaurentiuB
(Laurentiu B)
October 6, 2020, 3:53pm
33
Maybe this helps
openhab> smarthome:status LG_TV0_Channel
3_3_93_93_233_401_1
openhab> smarthome:status WebOS_state
3_3_93_93_233_401_1
["http://209.12.145.41:8080/rest/items/LG_TV0_Channel", "3_3_93_93_233_401_1", "{pattern=%s, readOnly=false, options=[{"value":"0_2_1_0_2_0_0","label":"1 - S 02"},{"value":"0_4_3_0_4_0_0","label":"3 - S 03"},{"value":"0_6_5_0_6_0_0","label":"5 - S 04"},{"value":"0_8_7_0_8_0_0","label":"7 - S 05"},{"value":"0_10_9_0_10_0_0","label":"9 - S 06"},{"value":"0_12_11_0_12_0_0","label":"11 - S 08"},{"value":"0_14_13_0_14_0_0","label":"13 - S 09"},{"value":"0_16_15_0_16_0_0","label":"15 - S 10"}......................
WebOS_state and LG_TV0_Channel output the same string. I will stop using WebOS_state item because is confusing
LaurentiuB
(Laurentiu B)
October 6, 2020, 4:13pm
34
It worked!
Thanks Scott!
I changed the rule like this:
Item LG_TV0_Channel changed
logWarn("Rules", "LG_TV0_Channel changed: {}", LG_TV0_Channel.state)
var current_label
val state_description_options = LG_TV0_Channel.stateDescription.options
if (option.value == LG_TV0_Channel.state.toString()) {
and the log is:
19:07:07.596 [WARN ] [.eclipse.smarthome.model.script.Rules] - Test: Start
19:07:07.615 [WARN ] [.eclipse.smarthome.model.script.Rules] - LG_TV0_Channel changed: 3_3_22_22_233_153_1
19:07:07.683 [WARN ] [.eclipse.smarthome.model.script.Rules] - state_description_options: [StateOption [value=0_2_1_0_2_0_0, label=1 - S 02], StateOption [value=0_4_3_0_4_0_0, label=3 - S 03]..............................................
19:07:07.720 [WARN ] [.eclipse.smarthome.model.script.Rules] - option: StateOption [value=0_2_1_0_2_0_0, label=1 - S 02]
19:07:07.735 [WARN ] [.eclipse.smarthome.model.script.Rules] - option: StateOption [value=0_4_3_0_4_0_0, label=3 - S 03]
19:07:07.749 [WARN ] [.eclipse.smarthome.model.script.Rules] - option: StateOption [value=0_6_5_0_6_0_0, label=5 - S 04]
it iterates all the values
19:07:10.187 [WARN ] [.eclipse.smarthome.model.script.Rules] - option: StateOption [value=3_8_17398_1014_238_2518_1, label=1014 - Realitatea FM]
19:07:10.195 [WARN ] [.eclipse.smarthome.model.script.Rules] - option: StateOption [value=3_11_17399_1015_251_2510_1, label=1015 - Radio Maria Ro]
19:07:10.203 [WARN ] [.eclipse.smarthome.model.script.Rules] - current_label: 22 - DIGI Sport 2 HD
19:07:10.209 [WARN ] [.eclipse.smarthome.model.script.Rules] - Test: End
LaurentiuB
(Laurentiu B)
October 6, 2020, 4:25pm
35
One more question how do I post the result to an item?
I tried
WebOS_label.postUpdate( current_label )
and I get an error
19:23:34.562 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Test DSL rule': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.postUpdate(org.eclipse.smarthome.core.items.Item,org.eclipse.smarthome.core.types.State) on instance: null
Also when savind the rule there is a validation message
19:24:45.829 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model '(7)_webos.rules', using it anyway:
Type cannot be derived
