I have 2 pressure sensors that I read via modbus to determine the differential on a spereator while a compressor is running. One is on the output line that is after a check valve and the other is on the tank before the seperator. When the compressor is running the differential pressure is only about 1psi but when the compressor turns off the seperator tank pressure is vented quickly dropping. The other pressure sensor is on the line out still connected to the plant air lines and it depressurizes at a much slower rate the differential calculation reaches -90psi at times. that reading is irrelevant because the compressor is not running at the time but it messes up my charting when it dips that low.
What I would like to do is use the power swtch input ON/OFF to stop it from calculating and return 0 when the compressor is turned off.
Here are my current rules.
var Number span1 = 158.6 / 65535
var Number span2 = (-16.1)
var Number span3 = 158.4 / 65535
var Number span4 = (-16.1)
rule "modbus pressure scale"
Item COMP_1_MAIN_Pressure changed
var Number temp = COMP_1_MAIN_Pressure.state as DecimalType
temp = span1 * temp + span2
postUpdate(COMP_1_MAIN_Pressure_div, temp)
rule "modbus sump pressure scale"
Item COMP_1_SUMP_Pressure changed
var Number temp = COMP_1_SUMP_Pressure.state as DecimalType
temp = span3 * temp + span4
postUpdate(COMP_1_SUMP_Pressure_div, temp)
rule "modbus sump differential pressure"
Item COMP_1_SUMP_Pressure_div changed
or Item COMP_1_MAIN_Pressure_div changed
var Number temp1 = COMP_1_SUMP_Pressure_div.state as DecimalType
var Number temp2 = COMP_1_MAIN_Pressure_div.state as DecimalType
var temp = temp1 - temp2
postUpdate(COMP_1_SUMP_Diff, temp)
Here are my items
Switch COMP_1_MAIN_Power "Compressor 1 Power" (modbus,comp) {modbus="slave3:0"}
Number COMP_1_MAIN_Pressure "Compressor 1 Pressure RAW" (modbus_raw) {modbus="slave4:0"}
Number COMP_1_SUMP_Pressure "Compressor 1 Sump Pressure RAW" (modbus_raw) {modbus="slave4:1"}
Number COMP_1_MAIN_Pressure_div "Compressor 1 Pressure [%.2f PSI]" <pressure> (comp,CompGraphPres,Pressure,modbus,mod_agg)
Number COMP_1_SUMP_Pressure_div "Compressor 1 Sump Pressure [%.2f PSI]" <pressure> (comp,CompGraphPres,Pressure,modbus,mod_agg)
Number COMP_1_SUMP_Diff "Compressor 1 Seperator Differential Pressure (MAX 10PSI) [%.2f PSI]" <diffpressure> (comp,CompGraphPres,Pressure,modbus,mod_agg)
