Is there a way to have items load first, and rules load last so that there are no issues resolving items? Also, it looks like openHAB 2 starts accepting REST queries before sitemap is loaded so that leads to a LOT of unknown sitemap messages. I guess both are not big issues, I would like to find a way to clean them up.
2017-06-29 10:09:57.374 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'testing.rules'
2017-06-29 10:09:57.478 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'water.rules'
2017-06-29 10:09:57.509 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'driveway.rules'
2017-06-29 10:09:57.735 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'pool.rules'
2017-06-29 10:09:57.823 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'samsungtv.rules'
2017-06-29 10:09:57.924 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'temperature.rules', using it anyway:
The method toDateMidnight() from the type DateTime is deprecated
2017-06-29 10:09:57.927 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'temperature.rules'
2017-06-29 10:09:58.283 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'appliances.rules'
2017-06-29 10:09:58.405 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'notify.rules'
2017-06-29 10:09:58.530 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'propane.rules'
2017-06-29 10:09:58.874 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'insteon.rules'
2017-06-29 10:09:58.905 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'doorbell.rules'
2017-06-29 10:09:59.099 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'power.rules'
2017-06-29 10:09:59.190 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.rules'
2017-06-29 10:09:59.229 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'bathroom.rules'
2017-06-29 10:09:59.587 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'generator.rules'
2017-06-29 10:09:59.628 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'clock.rules', using it anyway:
There is no context to infer the closure's argument types from. Consider typing the arguments or put the closures into a typed context.
2017-06-29 10:09:59.628 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'clock.rules'
2017-06-29 10:10:00.016 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ultrasonic_level.rules'
2017-06-29 10:10:00.867 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'outback.rules'
2017-06-29 10:10:01.067 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'cameras.rules'
2017-06-29 10:10:01.113 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'alarms.rules', using it anyway:
2017-06-29 10:10:01.114 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'alarms.rules'
2017-06-29 10:10:01.306 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'dmx.rules', using it anyway:
2017-06-29 10:10:01.307 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'dmx.rules'
2017-06-29 10:10:01.358 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'chicken_coop.rules'
2017-06-29 10:10:03.306 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'hvac.rules'
2017-06-29 10:10:03.821 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule Ping Pool Sensors: An error occurred during the script execution: The name 'Pool_Temperature' cannot be resolved to an item or type.
2017-06-29 10:10:03.821 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule Update inside average temperature and humidity: An error occurred during the script execution: The name 'Avg_Temperature' cannot be resolved to an item or type.
2017-06-29 10:10:03.898 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule Water Quality: An error occurred during the script execution: The name 'Water_Quality_A' cannot be resolved to an item or type.
2017-06-29 10:10:03.899 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule Water Rate: An error occurred during the script execution: The name 'Water_Meter' cannot be resolved to an item or type.
2017-06-29 10:10:04.747 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule Ping Sensors: An error occurred during the script execution: The name 'Hydrogen_Peroxide_Sensor' cannot be resolved to an item or type.
2017-06-29 10:10:04.749 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule Check Generator and Increment Runtimes: An error occurred during the script execution: The name 'Generator_Status' cannot be resolved to an item or type.
2017-06-29 10:10:04.754 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'amazondashbutton.things'
2017-06-29 10:10:04.761 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'neato.things'
2017-06-29 10:10:04.791 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zwave.things'
2017-06-29 10:10:04.804 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lifx.things'
2017-06-29 10:10:05.096 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.097 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.097 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule Water Rate: An error occurred during the script execution: The name 'Water_Meter' cannot be resolved to an item or type.
2017-06-29 10:10:05.100 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'autelis.things'
2017-06-29 10:10:05.103 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.things'
2017-06-29 10:10:05.107 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at
2017-06-29 10:10:05.180 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'nest.items'
2017-06-29 10:10:05.211 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2017-06-29 10:10:05.215 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.216 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mqtt-temperature.items'
2017-06-29 10:10:05.222 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'weather.items'
2017-06-29 10:10:05.234 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zwave-switches.items'
2017-06-29 10:10:05.258 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'modbus.items'
2017-06-29 10:10:05.295 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'air-quality.items'
2017-06-29 10:10:05.301 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'propane.items'
2017-06-29 10:10:05.304 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.305 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.306 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.307 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'pool.items'
2017-06-29 10:10:05.314 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.315 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.316 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.316 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zwave-locks.items'
2017-06-29 10:10:05.326 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.327 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.329 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'occupants.items'
2017-06-29 10:10:05.333 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.335 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.336 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'hvac.items'
2017-06-29 10:10:05.345 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.349 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mqtt-power.items'
2017-06-29 10:10:05.364 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.365 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.367 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zwave-outlets.items'
2017-06-29 10:10:05.374 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.375 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.384 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.385 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.385 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zwave-thermostats.items'
2017-06-29 10:10:05.468 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.469 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.474 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'insteon.items'
2017-06-29 10:10:05.515 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.516 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.517 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'dmx.items'
2017-06-29 10:10:05.521 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'vehicles.items'
2017-06-29 10:10:05.527 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.529 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'water.items'
2017-06-29 10:10:05.535 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'cameras.items'
2017-06-29 10:10:05.539 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'neato.items'
2017-06-29 10:10:05.554 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'appliances.items'
2017-06-29 10:10:05.558 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'christian_tabler.items'
2017-06-29 10:10:05.589 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lifx.items'
2017-06-29 10:10:05.795 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'samsungtv.items'
2017-06-29 10:10:05.801 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'power.items'
2017-06-29 10:10:05.898 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2017-06-29 10:10:05.901 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.902 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2017-06-29 10:10:05.903 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.904 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:05.904 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'db4o.persist'
2017-06-29 10:10:05.906 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
2017-06-29 10:10:05.907 [INFO ] [est.sitemap.internal.SitemapResource] - Received HTTP GET request at 'http://10.88.64.4:8080/rest/' for the unknown sitemap 'christian_tabler'.
2017-06-29 10:10:06.116 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'christian_tabler.sitemap'
