Hello, everyone,
I’m in the process of writing an editable chart widget for the UI.
But I have the problem that certain data from the props are not taken over.
On the one screenshot you can see that instead of the value of the props.period, the code itself is displayed in the chart.
Does anyone know the problem and maybe already has a solution for it?
uid: Chart-Card
tags: []
props:
parameters:
- description: Chart heading
label: Title
required: false
type: TEXT
- description: Unit for the X axis.
label: Unit
required: true
type: TEXT
- default: D
description: Period for Y axis. See openHAB doc oh-chart for options.
label: Period
required: false
type: TEXT
- description: A name which will appear on tooltips and labels for item 1.
label: Item name 1
required: false
type: TEXT
- context: item
description: The item 1 whose persisted data to display.
label: Item 1
required: true
type: TEXT
- default: "1"
description: The type (Line, Bar, Heatmap, Scatter) of the series.
label: Type item 1
required: false
type: INTEGER
min: 1
max: 4
- description: A name which will appear on tooltips and labels for item 2.
label: Item name 2
required: false
type: TEXT
- context: item
description: The item 2 whose persisted data to display.
label: Item 2
required: false
type: TEXT
- default: "1"
label: Type item 2
required: false
type: INTEGER
min: 1
max: 4
- description: A name which will appear on tooltips and labels for item 3.
label: Item name 3
required: false
type: TEXT
- context: item
description: The item 3 whose persisted data to display.
label: Item 3
required: false
type: TEXT
- default: "1"
label: Type item 3
required: false
type: INTEGER
min: 1
max: 4
- description: A name which will appear on tooltips and labels for item 4.
label: Item name 4
required: false
type: TEXT
- context: item
description: The item 4 whose persisted data to display.
label: Item 4
required: false
type: TEXT
- default: "1"
label: Type item 4
required: false
type: INTEGER
min: 1
max: 4
- description: A name which will appear on tooltips and labels for item 5.
label: Item name 5
required: false
type: TEXT
- context: item
description: The item 5 whose persisted data to display.
label: Item 5
required: false
type: TEXT
- default: "1"
label: Type item 5
required: false
type: INTEGER
min: 1
max: 4
parameterGroups: []
timestamp: Aug 2, 2022, 7:42:18 PM
component: f7-card
title: =props.title
slots:
default:
- component: oh-chart
chartType: ""
period: =props.period
slots:
grid:
- component: oh-chart-grid
includeLabels: true
xAxis:
- component: oh-time-axis
gridIndex: 0
yAxis:
- component: oh-value-axis
gridIndex: 0
gridIndex: 0
series:
- component: oh-time-series
gridIndex: 0
xAxisIndex: 0
yAxisIndex: 0
type: =props.type1
item: =props.item1
gridIndex: 0
xAxisIndex: 0
yAxisIndex: 0
type: =props.type2
item: =props.item2
gridIndex: 0
xAxisIndex: 0
yAxisIndex: 0
type: =props.type3
item: =props.item3
tooltip:
- component: oh-chart-tooltip
confine: true
smartFormatter: true
legend:
- component: oh-chart-legend
bottom: 3
type: scroll
dataZoom:
- component: oh-chart-datazoom
type: inside
I have one additional question. Is it now possible to expand the props dynamically (repeat/loop)?
Best regards,
Björn
- Platform information:
- Hardware: Raspberry Pi 4
- OS: Raspbian GNU/Linux 11 (bullseye)
- Java Runtime Environment: openjdk version 1.8.0_312
- openHAB version: openHAB 3.3.0 - Release Build
