Configuration for IKEA RGB Bulb LED2109G6 via Zigbee2Mqtt
I want to add a IKEA Tradfri RGB Bulb (LED2109G6) and a IKEA Switch (LED2109G6) via Zigbee2Mqtt by Text to my OH Installation.
Has anybody examples of the .things , .items , transformation and maybe also some .rule files allready working?
Thanks in advance,
Ingo
Because there was no answer, I tried myself. Maybe it is of interesst for anybody:
copied from the net to put in the “transform” folder:
setTradfriCTstartup.js
(function(x){
	var color_temp_stratup = (x * 350) + 150;		// 0-100 = 250-454
	//var color_temp = (500 - (x * 350));		// 0-100 = 500-100
	if(color_temp_stratup > 500) color_temp_stratup = 454
	if(color_temp_stratup < 250) color_temp_stratup = 250
    var result = new Object();
    result.color_temp_startup = color_temp_startup;
    return JSON.stringify(result);
})(input)
setZigbeeBrightness.js
(function(x){
    var brightness = (x/100)*255;
	if(brightness > 255) brightness = 255
	if(brightness < 0) brightness = 0
    result.brightness = brightness;
})(input)
setTradfriCT.js
(function(x){
	var color_temp = (x * 2.04) + 250;		// 0-100 = 250-454
	if(color_temp > 454) color_temp = 454
	if(color_temp < 250) color_temp = 250
    result.color_temp = color_temp;
})(input)
setZigbeeEffect.js
(function(x){
	var effectid = x;
    result.effect = effectid;
})(input)
in the .things file:
// IKEA Tradfri
        // IKEA Bulb 01 RGB
        Type switch : IKEA_Bulb_01_switch           "Ikea_Bulb_01 State"            [stateTopic="zigbee2mqtt/IKEA_Bulb_01", transformationPattern="JSONPATH:$.state", commandTopic="zigbee2mqtt/IKEA_Bulb_01/set", on="ON", off="OFF"]
        Type dimmer : IKEA_Bulb_01_brightness       "Ikea_Bulb_01 Brightness"       [stateTopic="zigbee2mqtt/IKEA_Bulb_01", transformationPattern="JSONPATH:$.brightness", commandTopic="zigbee2mqtt/IKEA_Bulb_01/set",transformationPatternOut="JS:setZigbeeBrightness.js"]
        Type string : IKEA_Bulb_01_brightnessMove   "Ikea_Bulb_01 Brightness Move"  [commandTopic="zigbee2mqtt/IKEA_Bulb_01/set/brightness_move"]
        Type dimmer : IKEA_Bulb_01_color_temp       "Ikea_Bulb_01 Color_Temp"       [stateTopic="zigbee2mqtt/IKEA_Bulb_01", transformationPattern="JSONPATH:$.color_temp", commandTopic="zigbee2mqtt/IKEA_Bulb_01/set",transformationPatternOut="JS:setTradfriCT.js"]
//        Type dimmer : IKEA_Bulb_01_color_temp       "Ikea_Bulb_01 Color_Temp"       [stateTopic="zigbee2mqtt/IKEA_Bulb_01", transformationPattern="JSONPATH:$.color_temp", commandTopic="zigbee2mqtt/IKEA_Bulb_01/set",transformationPatternOut="JS:setZigbeeCT.js"]
        Type dimmer : IKEA_Bulb_01_color_temp_start "Ikea_Bulb_01 Color_Temp_start" [stateTopic="zigbee2mqtt/IKEA_Bulb_01", transformationPattern="JSONPATH:$.color_temp_startup", commandTopic="zigbee2mqtt/IKEA_Bulb_01/set",transformationPatternOut="JS:setTradfriCTstartup.js"]
        Type colorHSB : IKEA_Bulb_01_color          "Ikea_Bulb_01 Color"            [stateTopic="zigbee2mqtt/IKEA_Bulb_01", commandTopic="zigbee2mqtt/IKEA_Bulb_01/set",transformationPatternOut="JS:HSBtoRGB.js"]
        Type number : IKEA_Bulb_01_Link             "Ikea_Bulb_01 Link"             [stateTopic="zigbee2mqtt/IKEA_Bulb_01", transformationPattern="JSONPATH:$.linkquality"]
       // IKEA Switch 01 mobiler Schalter
        Type string : IKEA_Switch_01_Action             "Ikea Switch 01 Action"             [stateTopic="zigbee2mqtt/IKEA_Switch_01", transformationPattern="JSONPATH:$.action"]
        Type number : IKEA_Switch_01_Action_Duration    "Ikea Switch 01 Action Duration"    [stateTopic="zigbee2mqtt/IKEA_Switch_01", transformationPattern="JSONPATH:$.action_duration"]
        Type number : IKEA_Switch_01_Battery            "Ikea Switch 01 Battery"            [stateTopic="zigbee2mqtt/IKEA_Switch_01", transformationPattern="JSONPATH:$.battery"]
        Type number : IKEA_Switch_01_Link               "Ikea Switch 01 Link"               [stateTopic="zigbee2mqtt/IKEA_Switch_01", transformationPattern="JSONPATH:$.linkquality"]
.items
// IKEA Bulb 01 (RGB)
Switch      IKEA_Bulb_01_Switch               "Ikea Bulb 01: [%s]"        (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Bulb_01_switch"}
Dimmer      IKEA_Bulb_01_Brightness           "IKEA Bulb 01: Helligkeit [%.0f]"                                                          (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Bulb_01_brightness"}
String      IKEA_Bulb_01_BrightnessMove       "IKEA Bulb 01: Helligkeit Move"                                                            (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Bulb_01_brightnessMove"}
Number      IKEA_Bulb_01_Bright
Number      IKEA_Bulb_01_Link                 "IKEA Bulb 01: Linkquality [%s]"                                     <qualityofservice>    (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Bulb_01_Link"}
DateTime    IKEA_Bulb_01_lastseen             "IKEA Bulb 01: zuletzt gesehen [%1$td.%1$tm.%1$tY %1$tH:%1$tM]"      <time>                (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Bulb_01_Link" [profile="timestamp-update"]}
Color       IKEA_Bulb_01_Color                "IKEA Bulb 01: Farbe"        (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Bulb_01_color"}
Dimmer      IKEA_Bulb_01_Temp                 "IKEA Bulb 01: FarbTemperatur"                                                             (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Bulb_01_color_temp"}
Dimmer      IKEA_Bulb_01_Temp_Start           "IKEA Bulb 01: FarbTemperatur Start"                                                       (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Bulb_01_color_temp_start"}
// IKEA Switch 01
Number      IKEA_Switch_01_Link               "IKEA Switch 01: Linkquality [%s]"                                   <qualityofservice>    (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Switch_01_Link"}
String      IKEA_Switch_01_Action             "IKEA Switch 01: Action"        (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Switch_01_Action"}
Number      IKEA_Switch_01_Action_Duration    "IKEA Switch 01: Action Duration [%.5f]"                                                   (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Switch_01_Action_Duration"}
Number      IKEA_Switch_01_Battery            "IKEA Switch 01: Battery [%s]"                                       <battery>             (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Switch_01_Battery"}
DateTime    IKEA_Switch_01_lastseen           "IKEA Switch 01: zuletzt gesehen [%1$td.%1$tm.%1$tY %1$tH:%1$tM]"    <time>                (IKEA_Bulbs)    {channel="mqtt:topic:RaspiMosquitto:ZigBee2MQTT:IKEA_Bulb_01_Link" [profile="timestamp-update"]}
.rules
rule "Ikea Switch 01"
		Item IKEA_Switch_01_Action received update
logInfo("Ikea Switch", "Action: " + IKEA_Switch_01_Action.state)
		if (IKEA_Switch_01_Action.state == "on") {					// Licht an
			sendCommand(IKEA_Bulb_01_Switch,ON)
		if (IKEA_Switch_01_Action.state == "off") {					// Licht aus
			sendCommand(IKEA_Bulb_01_Switch,OFF)
		if (IKEA_Switch_01_Action.state == "brightness_move_down") {			// Licht dunkler
      sendCommand(IKEA_Bulb_01_BrightnessMove, "-40")
		if (IKEA_Switch_01_Action.state == "brightness_move_up") {				// Licht heller
      sendCommand(IKEA_Bulb_01_BrightnessMove, "40")
		if (IKEA_Switch_01_Action.state == "brightness_stop") {           // Licht stop dimming
      sendCommand(IKEA_Bulb_01_BrightnessMove, "0")
		if (IKEA_Switch_01_Action.state == "arrow_left_click") {					// Licht stop dimming
      var ColorTemp = (IKEA_Bulb_01_Temp.state as Number) - 10
      if (ColorTemp < 1) ColorTemp = 0
      sendCommand(IKEA_Bulb_01_Temp,ColorTemp)
		if (IKEA_Switch_01_Action.state == "arrow_right_click") {					// Licht stop dimming
      var ColorTemp = (IKEA_Bulb_01_Temp.state as Number) + 10
      if (ColorTemp > 100) ColorTemp = 100
Maybe it helps…
