Hi.
I tried to add the file ESH-INF/binding/binding.xml for my Powermax 1.x binding.
In my OH2 distro (downloaded the 26th of March), I uninstalled the Powermax bundle, then put my new compiled jar file in the addons directory and restarted OH. Then I discovered as expected in Paper UI / Configuration / Bindings a new entry foir my binding with two buttons “CONFIGURE” and “MORE”. Clicking on “MORE” delivers what is expected but when I click on “CONFIGURE”, nothing at all happens.
Here is my binding.xml file:
<?xml version="1.0" encoding="UTF-8"?>
<binding:binding id="powermax" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:binding="http://eclipse.org/smarthome/schemas/binding/v1.0.0"
xsi:schemaLocation="http://eclipse.org/smarthome/schemas/binding/v1.0.0 http://eclipse.org/smarthome/schemas/binding-1.0.0.xsd">
<name>Visonic PowerMax Binding</name>
<description>The Visonic PowerMax binding interfaces with Visonic PowerMax and PowerMaster alarm panel series.</description>
<author>lolodomo</author>
<config-description>
<parameter name="serialPort" type="text" required="false">
<context>network_address</context>
<label>Serial port</label>
<description>The serial port to use for connecting to the serial interface of the PowerMax alarm system e.g. COM1 for Windows and /dev/ttyS0 or /dev/ttyUSB0 for Linux.</description>
</parameter>
<parameter name="ip" type="text" required="false">
<label>IP address</label>
<description>The IP address to use for connecting to the Ethernet interface of the PowerMax alarm system.</description>
</parameter>
<parameter name="tcpPort" type="integer" min="0" required="false">
<label>TCP port</label>
<description>The TCP port to use for connecting to the Ethernet interface of the PowerMax alarm system.</description>
</parameter>
<parameter name="motionOffDelay" type="integer" min="1" unit="min" required="false">
<label>Motion reset delay</label>
<description>The delay in minutes to reset a motion detection.</description>
<default>3</default>
<advanced>true</advanced>
</parameter>
<parameter name="allowArming" type="boolean" required="false">
<label>Allow arming</label>
<description>Enable or disable arming the PowerMax alarm system from openHAB.</description>
<default>false</default>
</parameter>
<parameter name="allowDisarming" type="boolean" required="false">
<label>Allow disarming</label>
<description>Enable or disable disarming the PowerMax alarm system from openHAB.</description>
</parameter>
<parameter name="pinCode" type="text" required="false">
<context>password</context>
<label>PIN code</label>
<description>The PIN code to use for arming/disarming the PowerMax alarm system from openHAB. Not required except when Powerlink mode cannot be used.</description>
</parameter>
<parameter name="forceStandardMode" type="boolean" required="false">
<label>Force standard mode</label>
<description>Force the standard mode rather than trying using the Powerlink mode.</description>
</parameter>
<parameter name="panelType" type="text" required="false">
<label>Panel type</label>
<description>Define the panel type. Only required when forcing the standard mode.</description>
<limitToOptions>true</limitToOptions>
<options>
<option value="PowerMax">PowerMax</option>
<option value="PowerMax+">PowerMax+</option>
<option value="PowerMaxPro">PowerMax Pro</option>
<option value="PowerMaxComplete">PowerMax Complete</option>
<option value="PowerMaxProPart">PowerMax Pro Part</option>
<option value="PowerMaxCompletePart">PowerMax Complete Part</option>
<option value="PowerMaxExpress">PowerMax Express</option>
<option value="PowerMaster10">PowerMaster 10</option>
<option value="PowerMaster30">PowerMaster 30</option>
</options>
<default>PowerMaxPro</default>
</parameter>
<parameter name="autoSyncTime" type="boolean" required="false">
<label>Sync time</label>
<description>Automatic sync time at openHAB startup.</description>
</parameter>
</config-description>
</binding:binding>
I have an additional question; what is exactly “network_address” as parameter context ? Shall I use it for a serial port ?
