rkrisi
(Kristof Rado)
April 3, 2018, 7:47pm
1
Dear Community!
I have a chart in my sitemap which shows my family members phone’s battery level. Most of them was configured through Paper UI. Today when I restarted the system, these items were gone from this chart. When I opened the configuration in Paper UI, there were no parent group selected, so I think that’s why it is not working. However I couldn’t re-add the group to these items. When I select the group save it, it says that “Item updated”, but if I reopen the config page, no group is shown there. Is there anything I’m missing? Or just a bug?
I have read somewhere that I need to use persistance, otherwise these data is gone when restarting, but I have restarted several times these days and it didn’t had any problems like this…
vzorglub
(Vincent Regaud)
April 3, 2018, 11:13pm
2
Can you post your items definitions, bindings and the log, thanks
rkrisi
(Kristof Rado)
April 4, 2018, 6:28pm
3
Yes, here it is:
//Basic Items
DateTime Today "Today"
//Weather Items
Number Temperature "Forecast Temperature [%.1f °C]" <temperature> (TemperatureGroup, cTemp) {weather="locationId=home, type=temperature, property=current"}
Number Temp_Feel "Temperature feel [%.1f °C]" <temperature> (TemperatureGroup, cTemp) {weather="locationId=home, type=temperature, property=feel"}
Number Humidity "Humidity [%d %%]" <humidity> (TemperatureGroup) {weather="locationId=home, type=atmosphere, property=humidity"}
String Condition "Condition [%s]" <sun> (TemperatureGroup) {weather="locationId=home, type=condition, property=text"}
Number Visibility "Visibility [%.1f km]" <visibility> (TemperatureGroup) {weather="locationId=home, type=atmosphere, property=visibility"}
Number Pressure "Pressure [%.1f mb]" <pressure> (TemperatureGroup) {weather="locationId=home, type=atmosphere, property=pressure"}
Number Ozone "Ozone [%d ppm]" <sun> (TemperatureGroup) {weather="locationId=home, type=atmosphere, property=ozone"}
Number UV_Index "UV Index [%d]" <sun> (TemperatureGroup) {weather="locationId=home, type=atmosphere, property=uvIndex, scale=0"}
Number Wind_Speed "Windspeed [%.1f km/h]" <wind> (TemperatureGroup) {weather="locationId=home, type=wind, property=speed"}
Group cTemp
//Switches
Switch Sonoff "Kitchen Lights" <light> (gKitchen) [ "Lighting" ] {mqtt=">[mosquitto:cmnd/sonoff/power:command:*:default],<[mosquitto:stat/sonoff/POWER:state:default]" }
String HarmonyHubButton
String Sonoff_Lwt "Kitchen Lights LastWill: [%s]" <controls_round> { mqtt="<[mosquitto:tele/sonoff/LWT:state:MAP(reachable.map)]" }
Number Sonoff_RSSI "Kitchen Lights RSSI: [%d%%]" <controls_round> { mqtt="<[mosquitto:tele/sonoff/STATE:state:JSONPATH($.Wifi.RSSI)]" }
String Sonoff_Current_FW_Available "Current Sonoff-Tasmota Release [%s]" <sonoff_basic> (Sonoff_Maintenance) { http="<[tasmotaRelease:10000:JSONPATH($[0].name)]"}
String Sonoff_Action "Sonoff Action" <sonoff_basic>
//Location
String KristofIPhone_LocationString "Kristof Location [%s]" <presence>
String ReKaIPhone_LocationString "Reka Location [%s]" <presence>
String EdinaIPhone_LocationString "Edina Location [%s]" <presence>
String BandiPhone_LocationString "Bandi Location [%s]" <presence>
//Entertainment
String Radio <radio>
String Sony { channel="harmonyhub:device:HarmonyHub:51475814:buttonPress" }
String Cisco { channel="harmonyhub:device:HarmonyHub:51081790:buttonPress" }
//Home and distance
Switch KristofIPhone_Home "Kristof Home or Away"
Switch ReKaIPhone_Home "Reka Home or Away"
Switch EdinaIPhone_Home "Edina Home or Away"
Switch BandiPhone_Home "Bandi Home or Away"
String Everyone_Home "Is Everyone at Home [%s]" <presence>
Number battery_period <iphone>
Number BandiPhone_BatteryLevel "Bandi battery level [%d %%]" <battery> (iBattery)
Location BandiPhone_Location
String BandiPhone_BatteryStatus "Bandi battery status"
However the other phone’s battery level are not in this item file, because it was set-up through PaperUI
The bindings which I use:
Sorry, but I was unable to upload my log. Should I look for something in it and post it there?
Also it seems, that I can’t even add anything to a group through PaperUI
vzorglub
(Vincent Regaud)
April 4, 2018, 8:29pm
4
You need to put the group item definition before the items belonging to that group
rkrisi
(Kristof Rado)
April 4, 2018, 9:23pm
5
The temperature graph is working good despite the group definition was after the items. However I don’t have that Group (iBattery) here in the items list, because I have added that group through PaperUI and also added these items (phone batteries) through PaperUI which is also not here…
rkrisi
(Kristof Rado)
April 4, 2018, 9:26pm
6
And now I have realised that all of the icons is gone after that restart which was set-up through PaperUI
vzorglub
(Vincent Regaud)
April 4, 2018, 9:37pm
7
I recommend setting up your items in files and not through the UI, although you should not have that problem.
rkrisi
(Kristof Rado)
April 4, 2018, 9:44pm
8
Ok, I’ll try that. What is the easiest way? Deleting from PaperUI and adding a new item to the items file?
vzorglub
(Vincent Regaud)
April 4, 2018, 10:55pm
9
Delete your items in the Paper UI and unlink the things
Then define your items by hand in an items file
You’ll have far more control over them
rkrisi
(Kristof Rado)
April 5, 2018, 1:17pm
10
Thanks, this solved the issue. Also other items which was set-up through PaperUI generated some error, I have added them in the items file, now these errors are gone!
vzorglub
(Vincent Regaud)
April 5, 2018, 1:52pm
11
Good, please like if you want and mark the thread as solved
