Configuration when loading the Habpanel
Good morning community,
Normally on every new device accessing my openHAB system the local memory is opened. There are then not my items but a black page. Only if you select my profile in the configuration the items will be displayed.
Is there a possibility that my Panel configuration will be selected on a new device when default is set?
I would be pleased about an answer.
Kind regards,
Mark Baumann
Can someone help?
Yes, that’s possible: open Paper UI, go to Configuration > Services, UI tab, Configure in the HABPanel card, type the name of your panel configuration (CIB) in the “initial panel configuration” box and save.
