"Configure widget" popup stays blank
Hey guys,
recently I ran into the issue that the “Configure widget” popup in the “Edit page” section stays empty. Doesn’t matter if I select a custom widget or a plain default one (like label cell). Basically like the situation in this thread.
First time I noticed it was when the knob widget didn’t show the knob anymore (rest of the widget worked fine). “Edit YAML” works as well, it’s only the Config Popup that stays empty.
What I tried so far:
  • switched from OH 5.1.1 to the snapshot branch (currently 5.2.0 b5244)
  • cleared the cache
  • Desktop (Chrome / Windows) and mobile (Android beta app)
Any ideas what could cause this?
I’m running Openhabian on an RPi 5.
Cheers
I’m on 5426 snapshot and I can confirm I’m seeing the same thing. This is worth filing an issue on the web-ui repository.
Could be related to this issue. I chimed in.
Edit: This is a Chrome issue. It does work in Edge.
OK, here’s the weird thing: After I tried it out in Edge, it worked again in both Chrome and the Android App.
