Issue of the topic: Cannot get it working / Error Items file
Hi there,
I’ve been experimenting with Openhab and now I’m testing in order to build a KNX home automation with it.
My first setup is pretty simple it’s a Gira IP Router 216700 (firmware 4.xx) and a Gira Dimmer 103100
I’m struggling to get the 2.4 binding configured however so I really hope somebody can help me (and prevent me from switching to IP Symcon )
The dimmer is working fine. (I’ve tested with a demo version of Symcon)
I’ve made the following groupadresses in ETS:"
1/1/4 Switch
1/1/5 Increase/Decrease
1/1/6 Strenght of light
1/1/7 Feedback switch
The things file looks as follows: (I’ve been trying several things the past hours)
Hi Udo,
Thanks very much for helping me.
I adjusted the .things file with the code.
I assume it’s working (no errors in the log after putting the ‘=’ outside the quotes)
I’m still getting the error for the .items file however:
Configuration model ‘Knx.items’ has errors, therefore ignoring it: [1,1]: missing EOF at ‘ï’
Groupaddress 1/1/6 for getting the dim level is not correct? In ETS it’s an output called ‘output light strength’ (translated from Dutch)
What other group address do you mean?
If 1/1/5 for increase/decrease should not be used (b.t.w. Symcon uses this GA), how can the dim level be adjusted then?
Ah. There should be two communication objects for brightness, one as output and one as input. openHAB likes to send absolute dimm level. Of course you could use INCREASE and DECREASE as command by using increaseDecrease CO.
There are some dimmers which need start-stop dimming, openHAB does not support this feature.
But still the same error:
2019-08-04 14:11:43.588 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘Knx.items’ has errors, therefore ignoring it: [1,1]: missing EOF at ‘ï’
In my understanding I defined 1/1/5 (symcon also sends the absolute value btw) as the GA to send the dimvalue to, and 1/1/6 as the GA to receive the actual dim value from.
Do you have an example how to configure then and how to program an adjustment of the dimmer (or do I still misunderstand?
While there is no rule for naming, I prefer a device specific naming.
3/5/20 is DPT 1.001 Switch (no status, because dimmer items use Number as Status)
3/5/22 is DPT 5.001 Set Dimm Level (openHAB will send the level to the device)
3/5/27 is DPT 5.001 Get Dimm Level (openHAB will receive the level from the device)
< is: “hey, openHAB, please read the Value once when starting.”
