I successfully installed OpenHAB 2.3 on my RasPi. I started configuring and added the KNX addon.
I looked in the Web how to configure OpenHAB and KNX, but all tutorials I found are doing the configuration via config files.
So my question is:
Can I configure a OpenHAB and KNX via the GUI only?
I tried, but it does not send any KNX telegrams yet. For the more advanced features I’ll have to change the config file, but I only want to switch one light on/off for a start…
And no, it’s not more powerful to configure by text files. There is really no difference between text configuration and configuration e.g. through Paper UI,other than if configuring via text files you have to type all the stuff by yourself (but in one single file) while when configuring via Paper UI you have to type only the values (GA, DPT and so on) in predefined fields, but you have to create the bridge and at least one thing separately and then configure all your channels on at least one thing.
