Thanks @chrismast ,
Your questions helped me find the problem.
The log displayed these line, which meant the Setpoint’s temperature changing commands were properly received in OpenHAB.
2021-09-28 22:11:02.516 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SalonAC_Temperature' received command 24.0
2021-09-28 22:11:02.518 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'SalonAC_Temperature' predicted to become 24.0
2021-09-28 22:11:02.524 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SalonAC_Temperature' changed from 23 to 24.0
2021-09-28 22:11:03.226 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'SalonAC_Temperature' received command 25.0
2021-09-28 22:11:03.227 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'SalonAC_Temperature' predicted to become 25.0
2021-09-28 22:11:03.233 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SalonAC_Temperature' changed from 24.0 to 25.0
2021-09-28 22:11:06.648 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SalonAC_Temperature' changed from 25.0 to 23
Which means, you were correct. The problem was in my AC transformation map file.
My trasformation file had these lines for the temperatures:
16=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[16.0]}]
17=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[17.0]}]
18=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[18.0]}]
19=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[19.0]}]
20=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[20.0]}]
21=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[21.0]}]
22=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[22.0]}]
23=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[23.0]}]
24=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[24.0]}]
25=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[25.0]}]
26=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[26.0]}]
27=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[27.0]}]
28=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[28.0]}]
29=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[29.0]}]
30=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[30.0]}]
meaning, the temperature changes actually did not reflect in the transformation map file, because the Setpoint changes were received as “23.0”, “24.0”, “25.0” whereas the transformation map file had “23”, “24”, “25” as the commands to listen to.
After changing the transformation file to this, the problem was solved and the command passed to the AC:
16.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[16.0]}]
17.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[17.0]}]
18.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[18.0]}]
19.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[19.0]}]
20.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[20.0]}]
21.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[21.0]}]
22.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[22.0]}]
23.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[23.0]}]
24.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[24.0]}]
25.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[25.0]}]
26.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[26.0]}]
27.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[27.0]}]
28.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[28.0]}]
29.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[29.0]}]
30.0=[{"component":"main", "capability":"thermostatCoolingSetpoint", "command":"setCoolingSetpoint","arguments":[30.0]}]
As always, thank you very much for your help
