Confusion between channels and channel triggers
I struggle to understand the difference between channels and channel triggers.
Take the astro binding for example: Astro - Bindings | openHAB
There are channels and channel triggers. If I want to write a rule that is executed every time sun:home:phase:name is updated, how would this rule look like?
Can I use
when Channel "astro:sun:home:phase:name#event" triggered
or not? It is not listed as trigger channel. But from the rules-dsl documentation, I can only use triggered on channels.
Sometimes I see name instead of name#event. How to know what syntax/scheme is correct?
Recent discussion
