Hello, im absolutly new to OpenHAB. My final plans are to controll my Panasonic TV with Android TV with my Alexa (my Panasonic TV has no Alexa integration, only Google Assistant)
Dokumentation says the following:
For the AndroidTV to be successfully accessed an on-screen PIN authentication is required on the first connection.
To begin the PIN process, send the text “REQUEST” to the pincode channel while watching your AndroidTV. A 6 digit PIN should be displayed on the screen.
To complete the PIN process, send the PIN displayed to the pincode channel. The display should return back to where it was originally.
If you are on a ShieldTV you must run that process a second time to authenticate the GoogleTV protocol stack.
This completes the PIN process. Upon reconnection (either from reconfiguration or a restart of OpenHAB), you should now see a message of “Login Successful” in openhab.log
My First Problem ist to Establish a working Android TV Binding.
I already created an item “GoogleTV_Pin_Code” linked with the PINCODE Channel. After i went to API explorer and
POST /items/GoogleTV_Pin_Code
as command i inserted REQUEST
and hit execute
this was my response (200)
content-length: 0
content-type: text/plain
date: Mon,08 May 2023 12:15:07 GMT
server: Jetty(9.4.46.v20220331)
Where is my misstake and could you give me some advises for my plan to control my android tv with alexa?
