Connect DreameHome (Xiaomi) to OpenHab
“Hello everyone, I’m diving into OpenHAB and I wanted to connect my vacuum cleaner (Dreame D10s Plus) to OpenHAB. Reading through the forums, I’ve seen that it would be ‘quite’ easy to connect Xiaomi Home, but the issue is that my vacuum cleaner isn’t compatible with Xiaomi Home, only with DreameHome. Has anyone encountered this issue before and found a solution? Could spoofing the data that the vacuum cleaner sends/receives be a way to use them on OpenHAB? Thanks in advance!”
May be this thread ( MIIO Binding - Execute RPC Command for Dreame D9 ) helps ? I don’t know if they are compatible.
