Dear All,
I am quiet new to openHAB and started with a configuration of a Z-Wave controller.
My current Setup is as following:
- Windows Server 2012 R2 with OpenHab and JDK 1.8.0_111 is up and running.
- Raspberry Pi 2 with Jessy and Z-Wave ZME*RAZ2 installed with RazBerry2 on TCP Port 8083 (Running)
But when adding the RaspBerry PI with the Binding for Z-Wave and Port 8083 it is shown as offline.
I looked through some topics and only found a configuration of ZWave Controler and OpenHab on the same host.
Therefore I would be interested, if it is the only way, to connect ZWave to my OpenHab configuration, if I install both on the same host, or if I can connect the Raspberry PI somehow?
Thank you very much.
With best regards,
Robin
