Hi Markus, if you need a tester for MercedesMe, please let me know.
Hi all
Are there any plans to add a Toyota cars (via MyT) ?
Thanks ,
Slawek
HI,
the correct setup is
- A Volkswagen CarNet account/bridge thing having the credentials
- Once the account is connected the binding will retrieve the vehicle list and create the corresponding things. Donāt create them on your own
- Then add a WeConnect wallbox thing, put in the credentials
- Again the binding will retrieve the units (usually 1, maybe more)
MercedesMe implementation is on hold. I got the authorization working and connected a Web Socket, but this provides binary data. The is the MBDSK on GitHub and definitions in Google protobuf format, bute the generated code is 50k+ lines. I stopped here for now.
HI, not yet. Do you have information on the API? Is there public documentation? Are there implementations on GitHub etc.?
wow, now I get it. Stupid
My mistake was that I was only using the Volkwagen Account (Bridget) with the assigned cars (no ID). Then I tried to add the ID.Charger. There was no possibilty to enter the credentials (only an Identifier).
Now I add the Volkswagen ID Account (Bridget) and Iām able to enter the credentials in wallbox (bridget). everything fine, thx !!
Now I will start to configure ID.3 and ID.Charger
Here I found unofficial python functions for handling data from Toyota Connected services APIs via MyT service, seems that still works, today I had occasion to a bit play with this stuff
Hope this helps,
Slawek
I have found this Python script. Perhaps this can help for Mercedes Me?
Hello together,
i have two cars now with seat connect. The first one works fine. Now i try the second one and get an error.
Are the bridge work only with one car?
The VW bridge is working fine with 2 cars. When bridge is connected the two things (one for each car) are automatically found.
That doesnāt work and make no sense⦠I have only on connect account. And there are two cars. I have now 2 things and that doesnāt work also. So if i have a hue bridge i need one and get all my things and lamps. So why i need two things with same account data? I try it out and the vehicle stay offline. And now?
Edit: Solved it. Delete everything and start from scratch. Now i found with one account of car connect both cars.
fyi: If you are not already aware - one more reason to upgrade your OH
Hello Markus,
I tried to use org.openhab.binding.connectedcar-3.2.0-SNAPSHOT.jar on openhab āopenHAB 3.1.1 Release Buildā with my Seat car (Cupra Leon Sportstourer e-Hybrid).
I created the thing āSEAT Connect Account (CarNet)ā, it is online.
The car is afterwards detected automatically (I did not enter a security PIN) but the thing is offline.
openhab displays the following error:
Status: OFFLINE
COMMUNICATION_ERROR
General Error: class org.openhab.core.library.types.QuantityType cannot be cast to class org.openhab.core.library.types.DecimalType (org.openhab.core.library.types.QuantityType and org.openhab.core.library.types.DecimalType are in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @14487f4)
Do you have any ideas how I can fix it?
Thanks in advance
Hermann
Hier noch der stacktrace:
java.lang.ClassCastException: class org.openhab.core.library.types.QuantityType cannot be cast to class org.openhab.core.library.types.DecimalType (org.openhab.core.library.types.QuantityType and org.openhab.core.library.types.DecimalType are in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @14487f4)
at org.openhab.binding.connectedcar.internal.api.carnet.CarNetServiceStatus.serviceUpdate(CarNetServiceStatus.java:177) ~[?:?]
at org.openhab.binding.connectedcar.internal.api.ApiBaseService.update(ApiBaseService.java:88) ~[?:?]
at org.openhab.binding.connectedcar.internal.handler.ThingBaseHandler.updateVehicleStatus(ThingBaseHandler.java:456) ~[?:?]
at org.openhab.binding.connectedcar.internal.handler.ThingBaseHandler.lambda$1(ThingBaseHandler.java:400) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
you need to move to OH 3.2. 3.2 bindings are not running on 3.1 nor 3.0 or 2.x
Thank you for the fast reply. I updated to release 3.2 but the error is still the same.
Any other suggestions?
For me it seems that the error reason is a class cast exception.
I donāt konw the code but I think instead of using
QuantityType q = ...
DecimalType t = (DecimalType)q;
you have to use something like that:
DecimalType t = new DecimalType(q.toBigDecimal());
hmm, sounds like valid; I try to provide you an updated version
Me again⦠As i mentioned that i have two cars. One is an Ibiza and the other one is a Leon. I set both VIN, they are different. The Ibiza show the data from Leon⦠Sure i created different Items and Channels. Iām totally wiredā¦
MyAudi not working for 2 days. Audi customer service says by order of federal authorities (KBA) they need to take some actions regarding log4shell.
I got the following log errors:
2021-12-23 20:21:44.488 [WARN ] [.internal.api.carnet.BrandCarNetAudi] - WAUZZZ...: Unable to verify pairing or pairing not completed (status INPROCESS, userId V0PGZh..., code 287...)
2021-12-23 20:21:45.396 [INFO ] [ar.internal.handler.ThingBaseHandler] - WAUZZZ...: API Call failed: API call failed
Just as an idea for future enhancements: create a trigger channel in case API calls fail.
Not important to me, I just wanted to write down but I assume you already have that on your roadmap;-)
