Connecting HomeKit to light sensor: Percentage to lux conversion issue
I just did the upgrade to 4.0. One of the issues I can’t solve yet is around a light sensor (Livisi) that provides values in percentage. I want to connect this to HomeKit, which expects lux.
In OpenHab 3.4.3 I used this JS transformation for a rough conversion (not very accurate, but usable for me):
| Math.pow(2, parseInt(input)/9+2)
I could get this working in OpenHab 4.0.1 again as a Thing To Item transformation like this:
| Math.pow(2, parseFloat(input)/9+2)
For some reason I have to use parseFloat now instead of parseInt.
The light sensor item has Number:Dimensionless. I set the item metadata to Number:Illuminance
Now I see in the item the expected value, e. g. 322.3 lx. But the HomeKit integration throws an error:
19:32:22.406 [WARN ] [ristics.impl.base.FloatCharacteristic] - **Detected value out of range 322.5398. Returning max value instead. Characteristic io.github.hapjava.characteristics.impl.lightsensor.CurrentAmbientLightLevelCharacteristic@130469**
In Apple HomeKit I get 100 lux.
When I inspect the HomeKit configuration, I see:
openhab> openhab:homekit show 221276695
221276695 Lichtsensor Büro
Services:
  Service Type: LightSensorService (00000084-0000-1000-8000-0026BB765291)
    Characteristics:
      CurrentAmbientLightLevelCharacteristic: {"iid":0,"type":"6B","perms":["pr","ev"],"format":"float","value":100.0,"minValue":0.0,"maxValue":100.0,"minStep":0.00010,"unit":"lux"}
Why is the LightLevel characteristic set to expect a maxValue of 100? Is it still taking over the “percentage” from the Number:Dimensionless of the Thing?
I think I solved it myself by adding a configuration to the HomeKit metadata:
value: LightSensor.LightLevel
maxValue: 100000
Why this is necessary though I don’t understand as it should be the default maxValue for Illuminance.
