I own an Intex Spa (HB-20) since a bit more than one year. Tough thing with it, it that you’ve got to take care of it each and every day once filled if you want to be able to use it once the time has come.
Major issues being :
- water temperature has to be anticipated long enough when you want to use it (IIRW it grows 2°C by hours)
- water filtration has to be executed very frequently to keep it clean.
As it comes by default, with its local control panel, it is a real pain in the **ss to do on a frequent basis.
So started my searches on Internet.
So did I land on these two forum threads jeedom and domoticz with people having the same questions than me.
I got in touch with PaTiTan who provides modules based on this implementation.
A few days later, I received my module in the mailbox. Connections were really easy. The 3D printed connectors are really perfect and allows a completely removable installation on your SPA without any modification.
I must say that the module is really well packaged and built, and I am comfident it can face exterior conditions, temperatures and humidity.
Three minutes later, the module was online on my wifi network and fully working throught MQTT binding.
Configuration was quite easy with an MQTT thing, here is the YAML :
UID: mqtt:topic:localhost:spa
label: Intex PureSpa SB-H20
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:localhost
channels:
- id: bubble
channelTypeUID: mqtt:switch
label: Bulles
description: ""
configuration:
commandTopic: pool/command/bubble
stateTopic: pool/bubble
off: off
on: on
- id: filter
label: Filtration
description: ""
configuration:
commandTopic: pool/command/filter
stateTopic: pool/filter
off: off
on: on
- id: heater
label: Chauffage
description: ""
configuration:
commandTopic: pool/command/heater
stateTopic: pool/heater
off: off
on: on
- id: power
label: Power
description: ""
configuration:
commandTopic: pool/command/power
stateTopic: pool/power
off: off
on: on
- id: currentTemp
channelTypeUID: mqtt:number
label: Température Actuelle
description: ""
configuration:
stateTopic: pool/water/tempAct
unit: °C
- id: setpoint
label: Température Cible
description: ""
configuration:
commandTopic: pool/command/water/tempSet
unit: °C
min: 25
stateTopic: pool/water/tempSet
max: 40
- id: error
channelTypeUID: mqtt:string
label: Erreur
description: ""
configuration:
stateTopic: pool/error
- id: rssi
label: RSSI Wifi
description: ""
configuration:
stateTopic: wifi/rssi
unit: dBm
- id: wifi_state
label: Wifi Status
description: ""
configuration:
stateTopic: wifi/state
In fact, the only thing to take care of was that commands must be emitted in lower case while by default OH pushes in uppercase. This is handled in the YAML configuration.
