I use the MySQL persistence. Yesterday night my Synology updated to a new DSM version, which resulted in a reboot of the NAS. I run the MySQL instance on that NAS. After a short time, the NAS was up again - MySQL Connections were working again as soon as the server was started.
but in my log there were these Errors:
2016-12-12 03:39:50.676 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2016-12-12 03:39:50.677 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2016-12-12 03:39:50.686 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Could not store item 'Astro_MoonAzimuth' in database with statement 'INSERT INTO Item139 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;': No operations allowed after connection closed.
2016-12-12 03:39:50.743 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2016-12-12 03:39:50.747 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2016-12-12 03:39:50.752 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Could not store item 'Astro_SunElevation' in database with statement 'INSERT INTO Item134 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;': No operations allowed after connection closed.
2016-12-12 03:39:50.765 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2016-12-12 03:39:50.767 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2016-12-12 03:39:50.769 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Could not store item 'Astro_MoonElevation' in database with statement 'INSERT INTO Item138 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;': No operations allowed after connection closed.
2016-12-12 03:39:50.791 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2016-12-12 03:39:50.793 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2016-12-12 03:39:50.796 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Could not store item 'Astro_SunAzimuth' in database with statement 'INSERT INTO Item135 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;': No operations allowed after connection closed.
2016-12-12 03:45:03.887 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2016-12-12 03:45:03.889 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2016-12-12 03:45:03.892 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Could not store item 'Sensoren_Temp_OutN' in database with statement 'INSERT INTO Item49 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;': No operations allowed after connection closed.
I resaved the mysql.cfg without success, only a bundle:restart
in the openHAB console reset and reconnected the connection.
I’m using OH2 (build #637)
and 1.9.0.201612110211 openHAB mySQL Persistence bundle
Is this a known bug? https://github.com/openhab/openhab/issues/4504 refers to pre 1.9 if I can see correctly?
