I’m running the 1.7.1 runtime but using the latest 1.8.0-SNAPSHOT of insteonplm. I have a Insteon Hub hardware version 2244-222 and have enabled port 9761 using HouseLinc. I verified connection to the port using telnet.
When OpenHAB boots up I get the following in my log:
2016-01-07 05:15:49.003 [ERROR] [.i.i.driver.hub.OldHubIOStream] - cannot open connection to 10.0.0.3 port 9761:
java.net.ConnectException: Connection timed out
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[na:1.8.0]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:345) ~[na:1.8.0]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[na:1.8.0]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[na:1.8.0]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[na:1.8.0]
at java.net.Socket.connect(Socket.java:589) ~[na:1.8.0]
at java.net.Socket.connect(Socket.java:538) ~[na:1.8.0]
at java.net.Socket.(Socket.java:434) ~[na:1.8.0]
at java.net.Socket.(Socket.java:211) ~[na:1.8.0]
at org.openhab.binding.insteonplm.internal.driver.hub.OldHubIOStream.open(OldHubIOStream.java:48) ~[bundlefile:na]
at org.openhab.binding.insteonplm.internal.driver.Port.start(Port.java:136) [bundlefile:na]
at org.openhab.binding.insteonplm.internal.driver.Driver.startAllPorts(Driver.java:92) [bundlefile:na]
at org.openhab.binding.insteonplm.InsteonPLMActiveBinding.initialize(InsteonPLMActiveBinding.java:373) [bundlefile:na]
at org.openhab.binding.insteonplm.InsteonPLMActiveBinding.updated(InsteonPLMActiveBinding.java:272) [bundlefile:na]
at org.eclipse.equinox.internal.cm.ManagedServiceTracker$1.run(ManagedServiceTracker.java:183) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
at org.eclipse.equinox.internal.cm.SerializedTaskQueue$1.run(SerializedTaskQueue.java:36) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
2016-01-07 05:15:49.030 [DEBUG] [o.o.b.i.internal.driver.Port ] - failed to open port /hub/10.0.0.3:9761
2016-01-07 05:15:49.050 [DEBUG] [.o.b.i.InsteonPLMActiveBinding] - ports started
2016-01-07 05:15:49.053 [ERROR] [.o.b.i.InsteonPLMActiveBinding] - initialization complete, but found no ports!
Any ideas why this might not be working?
