new thread started here Modbus Transform
Might be dumb question, but should these new parameters only be available as colon-style : appendages to the basic connection data, or is there value in making them (also) individually accessible (so that defaults for other things can be left as-is)? Or does it already happen that way?
Trivial example
modbus:tcp.slave2.connection=192.168.6.180:502
already has an alternative format as
modbus:tcp.slave2.port=502
and of course āportā can be defaulted simply by
Itād be a lot clearer to read and understand, rather than
modbus:tcp.slave1.connection=192.168.1.200:502:50:500:100:2
when revisiting a config many months laterā¦
@rossko57, I think you have a very good point. Indeed, the configuration is pretty hard to read currently.
However, please note that your example is deprecated and alternative format with port is not supported any more. I do not know the exact history of the binding but I believe the support was dropped when connection was introduced (to replace port and host). This is really one of the bad sides of introducing new configuration, the old just lives on even though it might not be even supported anymore.
As you might remember we discussed possible configuration options in the beginning of the thread. My last proposal was presented in this post. There you had configuration parameters similar to your example.
As the new binding does not have a concept of different āendpoint parametersā (that is, inter transaction wait millis (serial+tcp), reconnectAfterMillis (tcp), interConnectDelayMillis (tcp), connectMaxTries (tcp)) for different openhab modbus slaves, it would make sense to separate connection configuration from the actual āregister/item definitionsā.
I would like to keep the configuration changes conservative, and not introduce new format if not considered absolutely necessary. I do hope that we can figure defaults (as discussed with mbs38 here) that work for 90% of people. For those who need extra performance, would deep dive into configurations ā perhaps with pre-made examples in the openhab.cfg as comments.
Just had an other idea as well, could we have nice comments in openhab.cfg, similar to @LeXLuther422ās example:
# (IP)
# | (PORT)
# | | (interTransactionDelayMillis)
# | | | (reconnectAfterMillis)
# | | | | (interConnectDelayMillis)
# | | | | | (connectMaxTries)
Would you find this usable as a starting point?
Best,
Sami
I would also agree with rossko57 about configuration. Ip port looks ok, as it is already kind of a standart:
But timeouts should be on separate line, as it is to hard to remember. In couple of weeks you will need to check manual to see which one means what.
Btw, thanks for good work, have not check yet how it works, but nice to see a progress.
Thanks for the comment @robiss. I would appreciate if you could test the latest version and get your feedback how it works.
I will think how the separation of parameters would make senseā¦
Will try to test it ASAP, i guess in a matter of month, since installation/setup in not quite there yet. Currently I`m building a new house and made a decision to go with rpi + openHab instead of loxone, as it looks like this setup gives more freedom and project makes a lot of progress ![]()
It certainly does make sense to keep these new, rather obscure, settings normally āout of sightā. (Obviously, assuming a sensible set of defaults exists, which shouldnāt be a problem)
I think the ascii-art style guide added to the config file is perfectly adequate for deciphering the parameters.
I think you are saying e.g. retries is generally applied across all slaves - so it is more like the āpollā parameter, applying to the whole binding, not the connection. So that putting these new parameters on the connection configs is perhaps not the right thing. Maybe it is more appropriate as part of the āpollā parameter (particularly the timing stuff)
It does all get a bit tricky without introducing the concept of a connection, from which multiple slaves could hang. With OH2 looming, it isnāt the time for such restructuring.
Yeah I think you got my point. Indeed itās somewhat similar to poll but like you said it might affect only some slaves (for example certain slow modbus tcp slave, or all serial slaves but not the tcp slaves).
Letās go with the simple approach and iterate on top of that if needed. I would like to get this out in the wild as now many are suffering with current version of the binding.
Not really familiar with OH2 but Iāve seen some examples of hiearchial configuration where this would fit much more nicely. Perhaps something to look at when OH2 is closer.
EDIT: Pull request submitted. Letās see how it goes!
Well done.
Could you post some further documentation about the configuration syntax in openhab.cfg so those reviewing the PR dontāt need to skim through the whole thread to piece things together?
And thx again for the great work. You really have transformed the thing from almost useless to pretty decent.
Best,
Max
Thank you!
Good idea about the documentation. Added some comments to the PR.
Best,
Sami
Hello.
Please help to solve problem with Modbus protocol.
My config:
- Arduino Pro mini with USB serial converter
- Openhab 1.8.1
when i use modbus simulator it always work, both the device and the program. when its work directly i donāt have stable transaction, it receives a signal or not.
I experimented with different version of SNAPSHOT, It does not help
openhab.cfg
modbus:poll=5
modbus:serial.slave1.connection=COM6:38400:8:none:1:rtu:280:100
modbus:serial.slave1.type=coil
modbus:serial.slave1.id=1
modbus:serial.slave1.start=2
modbus:serial.slave1.length=1
modbus:serial.slave2.connection=COM6:38400:8:none:1:rtu:280:100
modbus:serial.slave2.id=1
modbus:serial.slave2.start=2
modbus:serial.slave2.length=1
modbus:serial.slave2.type=discrete
modbus:serial.slave4.connection=COM6:38400:8:none:1:rtu:280:100
modbus:serial.slave4.id=1
modbus:serial.slave4.start=1
modbus:serial.slave4.length=1
modbus:serial.slave4.type=holding
openhab.log in normal mode 2016-03-30 16:25:22.334 [INFO ] [.o.core.internal.CoreActivator] - openHAB r - Pastebin.com
openhab.log in debug mode 16:30:14.471 [DEBUG] [.s.internal.SchedulerActivator:36 ] - Scheduler has been - Pastebin.com
Just out of curiosity why are you reading the same start address as a coil then as a discrete? slave1 and slave2
itās my mistake while writing code. coil - switch led, dicrete - contact. itās necessary to change address of discrete.
modbus:serial.slave2.start=3
normal 2016-03-30 17:55:58.640 [INFO ] [.o.core.internal.CoreActivator] - openHAB runti - Pastebin.com
debug 17:58:34.399 [DEBUG] [.s.internal.SchedulerActivator:36 ] - Scheduler has been - Pastebin.com
unfortunately its not working also
in experiment I use only coil register, but have same trouble
could you please try with latest of the latest version, available in the pull request.
Please note the changed configuration compared to previous snapshot versions, as discussed in the pull request. To keep things as simple as possible, please use this configuration
You probably need to comment out items referring to slaves.
I would also need to have higher level of logging. See this post on the details how to edit the logback_debug.xml.
After these changes, please start openhab using start_debug
Best
Sami
Sami, thank for attention.
System automatically hide my messages, it think that it was an advertisement.
I do all you written above.
New logfile
Thanks, this helps.
It can read something from the slave:
`19:21:52.888 [TRACE] [i.modbus.io.ModbusRTUTransport:127 ] - Managed to read at least one byte``
but when reading rest of the response, the serial library returns EOF immediately it seems (notice the same timestamp):
19:21:52.888 [ERROR] [i.modbus.io.ModbusRTUTransport:171 ] - Last request: 01 01 00 02 00 01 5c 0a
19:21:52.888 [ERROR] [i.modbus.io.ModbusRTUTransport:172 ] - failed to read: Error reading response (EOF)
Basically we would expect that the EOF error comes only after timeout has elapsed. The default timeout is 1500ms = 1.5 seconds:
19:21:52.898 [ERROR] [w.m.io.ModbusSerialTransaction:199 ] - execute try 1/3 error: I/O exception - failed to read. Request: net.wimpi.modbus.msg.ReadCoilsRequest@511d78d1 (unit id 1 & transaction 1). Serial parameters: SerialParameters@102c4d88[portName=COM6,baudRate=38400,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=rtu,echo=false,receiveTimeoutMillis=1500]
I have a bad feeling that this issue might be platform dependent ā not sure I know how the serial library openhab really works with different platforms.
Do you have the issue with other tools, such as modpoll?
Iām not test with modpol, but with PLC Simulator, it was no problem all work, logfile.
starting modpoll I have this result logfile
Actually I meant that you would try to read data with modpull. Please keep openhab closed at this time.
If you could then paste the modpoll output, that would be most useful.
Their website has pretty good documentation on the usage but Iām happy to help if needed.
Good day, ssalonen.
I test device with modpoll and received such a result:
modpoll -b 34800 -p none -m rtu -a 1 -r 1 -c 5 -t 0 COM4
modpoll 3.4 - FieldTalk⢠Modbus(R) Master Simulator
Copyright (c) 2002-2013 proconX Pty Ltd
Visit http://www.modbusdriver.com for Modbus libraries and tools.
Protocol configuration: Modbus RTU
Slave configurationā¦: address = 1, start reference = 1, count = 5
Communicationā¦: COM4, 34800, 8, 1, none, t/o 1.00 s, poll rate 1000 ms
Data typeā¦: discrete output (coil)
ā Polling slave⦠(Ctrl-C to stop)
Reply time-out!
Reply time-out!
Intresting result. First of all I test modpoll on my simulator program, be sure to select the correct settings of modpoll option.
with simulator
modpoll -b 34800 -p none -m rtu -a 1 -r 1 -c 5 -t 0 COM14
Communicationā¦: COM14, 34800, 8, 1, none, t/o 1.00 s, poll rate 1000 ms
[1]: 0
[2]: 1
[3]: 1
[4]: 1
[5]: 0
[1]: 0
[2]: 1
[3]: 1
[4]: 1
[5]: 0
then I change programm in Arduino (other modbus library) and test device on modpol:
modpoll -b 38400 -p none -m rtu -a 1 -r 20 -c 5 -t 0 COM3
Slave configurationā¦: address = 1, start reference = 20, count = 5
Communicationā¦: COM3, 38400, 8, 1, none, t/o 1.00 s, poll rate 1000 ms
[20]: 1
[21]: 0
[22]: 0
[23]: 0
[24]: 0
below you can see results with openhab:
my openhab.cfg
I have response to switch on localhost page.
Iām so sorry but Iām quite confused with the openhab logs you are pasting and the different devices you are trying out⦠If I understood correctly you have communication issue with modpoll as well as the openhab when communicating with real device.
If I understood correctly it seems to work with Arduino (COM3) but not real device (COM4)?
