ok well I have come up with another fun modbus config question I am trying to JS transform a number I am receiving but it’s not working
I have tried two different ways. The number is 6.10HZ the register returns 61 so I am dividing it by 10 the multiplying it by 60 to get RPM. When I have the JS inside the quotation marks it kicks an error when I have it outside the quotation marks it does nothing and I see the raw number.
HZ_RPM.js
(function(i){ return Math.round(i / 10 * 60); })(input)
Number Fan1RPM_H "Compressor Exaust Fan RPM [%d]" (modbus_raw,modbus) {modbus="slave5:0":JS(HZ_RPM.js)}
Number Fan1RPM_H "Compressor Exaust Fan RPM [%d]" (modbus_raw,modbus) {modbus="slave5:0:JS(HZ_RPM.js)"}
here is the error
org.openhab.model.item.binding.BindingConfigParseException: Register references should be either :X or :<X:>Y
at org.openhab.binding.modbus.internal.ModbusGenericBindingProvider$ModbusBindingConfig.<init>(ModbusGenericBindingProvider.java:207) ~[na:na]
at org.openhab.binding.modbus.internal.ModbusGenericBindingProvider.parseBindingConfig(ModbusGenericBindingProvider.java:108) ~[na:na]
at org.openhab.binding.modbus.internal.ModbusGenericBindingProvider.processBindingConfiguration(ModbusGenericBindingProvider.java:91) ~[na:na]
at org.openhab.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:348) [org.openhab.model.item_1.8.1.jar:na]
at org.openhab.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:324) [org.openhab.model.item_1.8.1.jar:na]
at org.openhab.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:171) [org.openhab.model.item_1.8.1.jar:na]
at org.openhab.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:390) [org.openhab.model.item_1.8.1.jar:na]
at org.openhab.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:159) [org.openhab.model.core_1.8.1.jar:na]
at org.openhab.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:100) [org.openhab.model.core_1.8.1.jar:na]
at org.openhab.model.core.internal.folder.FolderObserver.checkFolder(FolderObserver.java:142) [org.openhab.model.core_1.8.1.jar:na]
at org.openhab.model.core.internal.folder.FolderObserver.run(FolderObserver.java:99) [org.openhab.model.core_1.8.1.jar:na]
I am able to do it in a rule but it gets messy in the rules after a while and I have to make a new rule and output item for every item that needs the transform.
rule "fan div10 division"
Item Fan1RPM_H received update
var Number temp = (Fan1RPM_H.state as DecimalType)
temp = temp / 10 * 60
postUpdate(Fan1RPM_div, temp)
