Running OpenHab 3.4.5 (docker image)
I’d like to see how a BACnet device could be consulted by Openhab. Then I’ve downloaded and compiled the ConnectorIO 3.4.x BACnet binding with the following command:
mvn clean install -pl :org.connectorio.addons.kar.bacnet -am
Then copied the generated kar file into the addons directory and installed in opehab console by typing:
feature:install openhab-binding-co7io-bacnet
Everything seemed ok, no errors, but when I try to add a thing (by PaperUI or by editing a .thing file), I get this error:
[ig.discovery.internal.PersistentInbox] - Cannot create thing. No binding found that supports creating a thing of type co7io-bacnet:ipv4.
[l.thing.internal.GenericThingProvider] - No ThingHandlerFactory found for thing co7io-bacnet:ipv4:local (thing-type is co7io-bacnet:ipv4). Deferring initialization.
after several attempts for troubleshooting (setting more verbose logs for org.openhab, org.event and org.connectorio, switching to 4.0 opehab/connectorio version, trying to recompile in eclipse but unsuccessfully), I’m running out of ideas…maybe I’ve missed something for the addons installation ? Or the issue comes from the fact that I’m using a docker image ? Any hint will be more then appreciated, thank you so much
