Hello, I’m new to OpenHab so still examined things which can be simple and clear to you.
I have rule:
rule "light"
Item sw1 changed from OPEN to CLOSED
or Item sw1 changed from CLOSED to OPEN
logWarn("gt", "begin")
lock.lock()
logWarn("gt", "begin2")
try {
light.sendCommand(if(light.state == ON) OFF else ON)
} finally{
logWarn("gt", "end")
lock.unlock()
with items:
Contact sw1 "sw1" { gpio="pin:19" }
Switch light "light" { gpio="pin:18" }
So I want toggle light on contact change.
(Please don’t be surprised why I control light that way, this is simplified from multi-way wall switch, see in Multiway switch - #9 by dangif )
I’m using OpenHab2, updated few days ago.
Contact sw1 controls light and at beginning: sw1 closed = light on (sw1 open = light off)
Problem isn’t contact bounce, but that it sometimes lost synchronization and function reverse.
If I try to stress it and achieve contact bounce, then the log appear as:
(Initial state: light - ON, sw1 - CLOSED)
23:52:21.657 [INFO ] [marthome.event.ItemStateChangedEvent] - sw1 changed from CLOSED to OPEN
23:52:21.678 [INFO ] [marthome.event.ItemStateChangedEvent] - sw1 changed from OPEN to CLOSED
23:52:21.702 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin
23:52:21.712 [INFO ] [marthome.event.ItemStateChangedEvent] - sw1 changed from CLOSED to OPEN
23:52:21.721 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin
23:52:21.727 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin2
23:52:21.737 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin
23:52:21.784 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘light’ received command OFF
23:52:21.785 [WARN ] [rg.eclipse.smarthome.model.script.gt] - end
23:52:21.803 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin2
23:52:21.827 [INFO ] [marthome.event.ItemStateChangedEvent] - light changed from ON to OFF
23:52:21.862 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘light’ received command ON
23:52:21.860 [WARN ] [rg.eclipse.smarthome.model.script.gt] - end
23:52:21.875 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin2
23:52:21.926 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘light’ received command ON
^----- here arrived again ON and so from now the function is reversed (contact closed = light off)
23:52:21.928 [INFO ] [marthome.event.ItemStateChangedEvent] - light changed from OFF to ON
^^— this I probably need to arrive before previous ItemCommandEvent
23:52:21.933 [WARN ] [rg.eclipse.smarthome.model.script.gt] - end
23:52:23.147 [INFO ] [marthome.event.ItemStateChangedEvent] - sw1 changed from CLOSED to OPEN
^----- again closed to open?
23:52:23.155 [INFO ] [marthome.event.ItemStateChangedEvent] - sw1 changed from OPEN to CLOSED
23:52:23.185 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin
23:52:23.197 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin
23:52:23.198 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin2
23:52:23.211 [INFO ] [marthome.event.ItemStateChangedEvent] - sw1 changed from OPEN to CLOSED
^---- again open to closed?
23:52:23.219 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin
23:52:23.246 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘light’ received command OFF
23:52:23.250 [WARN ] [rg.eclipse.smarthome.model.script.gt] - end
23:52:23.291 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin2
23:52:23.316 [INFO ] [marthome.event.ItemStateChangedEvent] - light changed from ON to OFF
23:52:23.345 [WARN ] [rg.eclipse.smarthome.model.script.gt] - end
23:52:23.344 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘light’ received command ON
23:52:23.368 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin2
23:52:23.383 [INFO ] [marthome.event.ItemStateChangedEvent] - light changed from OFF to ON
23:52:23.387 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘light’ received command OFF
23:52:23.387 [WARN ] [rg.eclipse.smarthome.model.script.gt] - end
23:52:23.393 [INFO ] [marthome.event.ItemStateChangedEvent] - light changed from ON to OFF
23:52:24.682 [INFO ] [marthome.event.ItemStateChangedEvent] - sw1 changed from CLOSED to OPEN
23:52:24.709 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin
23:52:24.728 [WARN ] [rg.eclipse.smarthome.model.script.gt] - begin2
23:52:24.768 [INFO ] [smarthome.event.ItemCommandEvent ] - Item ‘light’ received command ON
23:52:24.768 [WARN ] [rg.eclipse.smarthome.model.script.gt] - end
23:52:24.826 [INFO ] [marthome.event.ItemStateChangedEvent] - light changed from OFF to ON
I can continue switching and light is toggled by contact change, but function is reversed.
For me it looks like if i guard/lock around the sendCommand, it didn’t guard against the real “ItemStateChangedEvent”?
Can I avoid this situation?
Or should I try find another solution and use toggle?
