My environment - running on a synology 1512+
**admin@NAS**:**/volume4/docker/openhab/userdata/backup**$ uname -a
Linux NAS 3.10.105 #25426 SMP Mon Dec 14 18:46:28 CST 2020 x86_64 GNU/Linux synology_cedarview_1512+
Here is the image at play - so it looks like it is the right/latest one
admin@NAS:/volume4/docker/openhab/userdata/backup$ sudo docker image ls
REPOSITORY TAG IMAGE ID CREATED SIZE
openhab/openhab latest 9808a627cfc8 2 weeks ago 691MB
admin@NAS:/volume4/docker/openhab/userdata/backup$ sudo docker image inspect 9808a627cfc8
"Id": "sha256:9808a627cfc82f8874d858aca6bb34c179a63b8924fb85180e46dc8bf6a07874",
"RepoTags": [
"openhab/openhab:latest"
"RepoDigests": [
"openhab/openhab@sha256:e2d3f7aa7f6565be446b045a0c7563c0f956762028378c5b93d97d8bccab5f37"
"Parent": "",
"Comment": "buildkit.dockerfile.v0",
"Created": "2021-04-21T12:58:21.392202655Z",
"Container": "",
"ContainerConfig": {
"Hostname": "",
"Domainname": "",
"User": "",
"AttachStdin": false,
"AttachStdout": false,
"AttachStderr": false,
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": null,
"Cmd": null,
"Image": "",
"Volumes": null,
"WorkingDir": "",
"Entrypoint": null,
"OnBuild": null,
"Labels": null,
"DDSM": false
"DockerVersion": "",
"Author": "",
"Config": {
"Hostname": "",
"Domainname": "",
"User": "",
"ExposedPorts": {
"5007/tcp": {},
"8080/tcp": {},
"8101/tcp": {},
"8443/tcp": {}
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"CRYPTO_POLICY=limited",
"EXTRA_JAVA_OPTS=",
"GROUP_ID=9001",
"JAVA_VERSION=11",
"KARAF_EXEC=exec",
"LC_ALL=en_US.UTF-8",
"LANG=en_US.UTF-8",
"LANGUAGE=en_US.UTF-8",
"OPENHAB_BACKUPS=/openhab/userdata/backup",
"OPENHAB_CONF=/openhab/conf",
"OPENHAB_HOME=/openhab",
"OPENHAB_HTTP_PORT=8080",
"OPENHAB_HTTPS_PORT=8443",
"OPENHAB_LOGDIR=/openhab/userdata/logs",
"OPENHAB_USERDATA=/openhab/userdata",
"OPENHAB_VERSION=3.0.2",
"USER_ID=9001",
"JAVA_HOME=/usr/lib/jvm/default-jvm"
"Cmd": [
"gosu",
"openhab",
"tini",
"-s",
"./start.sh"
"Healthcheck": {
"Test": [
"CMD-SHELL",
"curl -f http://localhost:${OPENHAB_HTTP_PORT}/ || exit 1"
"Interval": 300000000000,
"Timeout": 5000000000,
"Retries": 3
"ArgsEscaped": true,
"Image": "",
"Volumes": {
"/openhab/addons": {},
"/openhab/conf": {},
"/openhab/userdata": {}
"WorkingDir": "/openhab",
"Entrypoint": [
"/entrypoint"
"OnBuild": null,
"Labels": {
"maintainer": "openHAB <info@openhabfoundation.org>",
"org.label-schema.build-date": "2021-04-21T12:56:20Z",
"org.label-schema.description": "An open source, technology agnostic home automation platform",
"org.label-schema.docker.dockerfile": "/Dockerfile",
"org.label-schema.license": "EPL-2.0",
"org.label-schema.name": "openHAB",
"org.label-schema.url": "https://www.openhab.com/",
"org.label-schema.vcs-ref": "d4bc2cfb570ee70d74369fccd168ccbd078a4c79",
"org.label-schema.vcs-type": "Git",
"org.label-schema.vcs-url": "https://github.com/openhab/openhab-docker.git",
"org.label-schema.vendor": "openHAB Foundation e.V.",
"org.label-schema.version": "3.0.2"
"DDSM": false
"Architecture": "amd64",
"Os": "linux",
"Size": 690587156,
"VirtualSize": 690587156,
"GraphDriver": {
"Data": null,
"Name": "aufs"
"RootFS": {
"Type": "layers",
"Layers": [
"sha256:0270c2d5ad7267d4e20b234f5252bae2aa22b5fa0742b35a286d70532106269a",
"sha256:2ffef5e674bb23f01ba0cc5610e296b4c82fd6c2e0db25f1717e406edac20cd5",
"sha256:d42150b81e9d93973f4c705907b1cea1fe62c1f0c102ec18a5d169ea295a4eda",
"sha256:6da727ebe7704e0e78e9ed865668411e64d4eb0da4c6cfacc325be9079e23177",
"sha256:2e67737efcdad4e0674b383af5ba59ded64446c62fabc64b7c37cf4b1f0714ca",
"sha256:9b6378a28413389d86939db9f99afc6bc07acb23dfef2d240d4ce536a361e8b9"
"Metadata": {
"LastTagTime": "0001-01-01T00:00:00Z"
then the update.log:
admin@NAS:/volume4/docker/openhab/userdata/logs$ cat update.log
Image and userdata versions differ! Starting an upgrade.
You can find backup of userdata in /openhab/userdata/backup/userdata-2021-05-11T15-54-33.tar
openHAB Docker update script
You are already on openHAB 3.0.1
Your help is appreciated.
Axel
