Hi all
Since OH 4.0.0 M4 I can’t pull the docker Image. It fails imidiately.
Has some a solution for that?
Hi all
What error does it show?
Error | 2023/08/25 18:37:20 | Container | admin | Failed to do background task (create, openhab-1) |
Error | 2023/08/25 18:37:20 | Container | admin | Background task error for create openhab-1: 500 Server Error: Internal Server Error (missing signature key) |
That seems very QNAP specific which I do not know anything about. If nobody here knows what this is about, try https://forum.qnap.com/ instead.
I don’t know what is meant with signature key…
I don’t know either, but I did find this big topic about QNAP Docker issues with HTTP 500 errors, maybe it is related:
I don’t think this is the problem because I use 2.0.957 Container Station
Hi @Regedit, I upgraded some Docker tooling and build wborn/openhab:4.0.2
which works for me with Docker 1.13.1 on which I could reproduce the issue. Maybe you can give this image a try?
Thank you verry much for your effort. That looks realy great. Could you please add this to the normal build?
Updating the tooling did not completely fix it. After having another look it seems to be due to a change in the way manifests are created by default. I found some options to create manifests that are compatible again with older Docker versions. Can you test if wborn/openhab:4.0.3
works?
That works!
I’ve now merged the fix and also triggered some builds for:
openhab/openhab:3.4.5
openhab/openhab:4.0.3
openhab/openhab:4.1.0.M1
openhab/openhab:4.1.0-snapshot
So you should be able to enjoy the recent official openHAB releases again on old hardware.
Thank you verry much. Great work
